pic: Pneumatic Gate Valve Actuator
Re: pic: Pneumatic Gate Valve Actuator
wow. thats awesome!!! i will make one right now
The thought of that scares me.
ROFL i dont know why but that thread made me laugh irl
Nice!
Don't you think a ball value would work better?
How long is the over-all assembly? And what it weight? Last edited by Protronie : 01-10-2007 at 03:15. Reason: rethink |
#7
Matt looked into using ball valves, and could not find any that would work with the pneumatic cylinders we had available. They have too much friction, for one thing.
Weight of the complete valve assembly is actually relatively low, although I don't have a number and it's all assembled now so I can't weigh it. You can visit a hardware store and look over the valves, and see how the weight compares between gate valves and ball valves, if you'd like. |
#8
Thanks for sharing! I came accross this website to read more info on this great product: http://www.directindustry.com/indust...lve-61811.html
#9
Not spam sorry.
#10
So, let's start the discussion....would this combination of pneumatic and hydraulic components be FRC legal? If you think yes or no, please state the rule that would back up your descision.
#11
We actually changed out to a check valve from a well running in reverse on our new design. We use a cylinder to pull the barrel against the valve to unseat the valve and let air flow, then the air pressure left in the storage tank is used to reseal the valve when we let off the cylinder. It works pretty well but can let the o-ring blow out if you get too over zealous with the shirt flinging air pressure. |
#12
If using it as a mechanical valve to transmit, say small game pieces. Totally legal |
#13
I am thinking the ports are bigger than 1/8 npt, Not legal for FRC pneumatics. Since robot inspectors tend not to like anything unusual in the pneumatics, you would have a hard time getting it by them even if there were no specific rules against it.
I like the idea & the creativity though. Brass valves are typically rated WOG (water, oil, gas). And it doesn't have to be FRC legal. One concern would be the closing force is higher than the opening force (different areas in the cylinder. Sometimes an issue with wedges like gate valves. |
#14
Correct me if I'm wrong, but doesn't that only apply to solenoid valves (R77.C)? If this could be lumped in as a solenoid I would be amazed. But I completely agree that an inspector would probably not even feel the need to find a rule to make this not be allowed. Although the debate could be popcorn worthy as long as both sides stayed civil...
#15
Did I miss something? Why all the concern on "FRC legal" for a t-shirt cannon?
We've used an air actuated sprinkler valve similar to this on ours for years and it's worked great. |
| Pneumatic Actuator | Calvin_1631 | Pneumatics | 1 | 22-02-2007 11:12 |
| pneumatic actuator for storage tank | aksimhal | Pneumatics | 3 | 13-01-2007 23:19 |
| pic: pneumatic actuation of ball valve | Andrew Schuetze | Extra Discussion | 2 | 30-10-2006 08:40 |
| Gate Ramps | KWB@FIRST | General Forum | 14 | 17-10-2006 23:38 |
| Pneumatic Actuator limit? | Moshingkow | Rules/Strategy | 4 | 08-01-2003 02:16 |
