Go to Post I had so much to say but I dont know how to get it accross -- but to all of you that we were involved with this weekend, thankyou for everything -- we're changing lives, and we truly are moving mountains, in more ways than one. - Jacqui Sutton [more]
Unread 07-09-2014, 07:41
wgardner's Avatar
wgardner wgardner is offline
wgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to behold
[FTC]: Discrepancies between Game Video and Field Setup Guide
Hi All,
The official forums don't seem to be open yet (at least I see no team login and password on my team summary pages yet). I thought I'd share some thoughts on discrepancies I noticed between the game video and the field setup guide that caused us some confusion.
#1. From the field setup guide page 19, if you are looking at the kickstand with your alliance color, then your alliance's center goal should be to the left side of the center structure.
The very first shot of the field in the game video at 3:21 has it wrong! The blue alliance center goal is shown on the right of the blue alliance kickstand. It's also shown incorrectly at time 3:34, but correctly at times 3:28 and 3:45.
#2. There is no white tape on the official field, and the 3 center structure rotations are NOT 45 degrees from each other as shown in the video! In particular, the middle rotation shown in the game video at 3:47 is NOT correct. Page 19 of the field setup guide states that the middle rotation should have one edge of the center structure parallel with the perimeter, resulting in a rotation more like 60deg and less like 45deg.
#3. The orientations of the rotations shown for the center structure from 3:45 to 3:48 in the video are wrong! Page 19 of the field setup guide specifically states that the kickstands should rotate around the 90deg pointing at an alliance's ramp/platform, which results in the center goals rotating around the 90deg pointing at the initial starting points of the opposing alliance's rolling goals. The video shows the rotations being completely different with the kickstands rotating towards the rolling goals and the center goals rotating towards the ramp/platforms!
Essentially, the first rotation at 3:45 in the video is correct, but from there the two other rotations should be rotating COUNTER-CLOCKWISE from above, not CLOCKWISE from above as shown in the video!
Why do these matter?
#1 matters because if done correctly, each alliances kickstands AND center goals will always face their alliance side or at worst be perpendicular to the alliance sides. If done incorrectly, an alliance's center goal could end up facing away from an alliance! This would make autonomous center goal scoring virtually impossible and autonomous center goal defense very easy.
#2 matters because you may need to know the exact amounts of rotation of the center structure for any autonomous kickstand-knocking or center-goal-scoring.
#3 matters because you won't find the kickstands or center goals anywhere near where they're shown in the video for the 2nd and 3rd rotations in an actual match! Check page 19 of the field setup guide for their actual positions in the 3 rotations.
BTW, I really hope that the field setup guide is correct and that the video is wrong, because that would result in kickstands and goals pointing towards the starting position of an alliance making autonomous offense easier and autonomous defense harder. If the video is right, then autonomous center goal scoring is likely to be nearly impossible as the center goal would be pointing away from an alliance's starting positions!
Good luck to all teams!
CHEER4FTC website and facebook online FTC resources.
Providing support for FTC Teams in the Charlottesville, VA area and beyond.
Unread 07-09-2014, 09:23
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Re: [FTC]: Discrepancies between Game Video and Field Setup Guide
It wouldn't be the first time a game unveil video was incorrect to the rules. I remember a few years ago they had a simulated match in the video. At the end the scoring was wrong!
The video is just there to give you the basic understanding of the game, the rules and set up guide are what tournaments will have with them to set up and are the rules so go with that! That's what at 6:25 it says read the manual.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 07-09-2014, 12:39
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
I believe the order of precedence still applies in FTC: Q&A > Manual > Video
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 07-09-2014, 12:47
wgardner's Avatar
Yes, but the problem is that the setup is shown in the Field Setup Guide and not described in detail in the Game Manual.
Obviously a question to the Q&A should settle matters, but I hope teams don't go off and design autonomous routines expecting the center goal or kickstand to be somewhere that they'll never be based only on the video...
Unread 07-09-2014, 13:35
AKA: Nick Aarestad
I was trained as an FTA yesterday (which included building a field at kickoff), and I can tell you that unless FIRST tells us differently, the field setup guide is effectively our manual. I can't speak for individual match changes (rotation), but I can say there won't be white lines on the competition field unless something changes. Same goes for the center goal as you mentioned in number one.
Still, asking this in Q&A would clear up any remaining ambiguity.
tumblr | twitter
VEXU UMN (2015-??)
Unread 07-09-2014, 13:49
wgardner's Avatar
Great! Thanks. I will ask on Q&A when it opens.
Also, I've created a modified game video with annotations that point out the errors in the video. It's at the link below:
https://www.youtube.com/watch?v=RodL4HOBA5U
Unread 08-09-2014, 19:14
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
Not to mention that the robot continued to hit the clear tubing on the rolling goals. A big no-no in this game.
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 08-09-2014, 19:16
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
That's not true
<GS8> Robots may grab onto their own Alliance’s Rolling Goal in any location except for the Ball Tube. Incidental
contact with the Ball Tube during Scoring or pushing is allowed.
Robots that grab their Rolling Goals by the Ball
Tube will incur a Minor Penalty immediately and will incur additional Minor Penalties per five (5) second
interval that this situation continues.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 08-09-2014, 19:33
Oops, thanks, read that wrong...
www.valleyx2844.com
Unread 08-09-2014, 19:45
AKA: Roger Moore
Its better to point that out now and not try to design for a harder challenge.
Stronghold
Student 2013-2016
Unread 09-09-2014, 22:15
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Does anybody know what happens to the support pipes at the end of the autonomies mode, if knocked down will it just lay there or will it be removed by the field ref? if it is not knocked down will the ref remove it and release the balls. If the ref does not remove it than we have to knock it down and it will than be in the way for the rest of the game.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 09-09-2014, 22:31
AKA: Nick Aarestad
A cursory inspection of the game manual does not seem to reveal any rules about the removal of the kickstand. As it is not mentioned, I would assume it will be left on the field. This is reasonable question to ask in Q&A if you (or your students) cannot find anything in the manual concerning the kickstand post-release.
tumblr | twitter
VEXU UMN (2015-??)
Unread 10-09-2014, 08:55
joeweber's Avatar
Coach team 1322
At the Kettering University FTC Kickoff in Flint Mi. We tested the Kickstand and hitting it low it was difficult to dislodge but hitting it mid-way or high it went flying and would end up partially in the field area which would be a problem driving around it. I am sure that it could be removed during the pause after aton but it could not be removed during game play.
Unread 10-09-2014, 10:15
AKA: Nick Aarestad
Unless there's a rule specifically saying that field debris or specifically the kickstand should be removed from play, it's quite unlikely that refs wil be removing a released kickstand. I would not plan on it being removed unless you have a specific Q&A ruling or a rule in the manual to point to.
That being said, if a possible design you have is going to run into trouble if the kickstand is still on the field, you might want to rethink your design-- there are bigger obstacles on this field to locomotion than the kickstand.
tumblr | twitter
VEXU UMN (2015-??)
Unread 13-09-2014, 14:00
f42f52v52f6 f42f52v52f6 is offline
f42f52v52f6 is an unknown quantity at this point
In the game video, it implied that the points from the center goal could be worth up to 720 points because it already starts at 90 cm. Is the height of the balls scored during end game in the center goal measured from the base of the playing field or the base of the center goal?
