Go to Post The 3 probably stands for the number of years this season will take off your life - JohnSchneider [more]
Unread 25-02-2003, 20:01
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
drivers
More than one person driving at a time? We found this to be inefficeint and confusing.
Unread 25-02-2003, 20:04
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
Do you have anything on your control board? Our co-driver operates the control board, as our joysticks are on a seperate panel.
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 25-02-2003, 20:10
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
We have a driver who does the driving thing with just 2 joysticks that have the y axis controlling 1 side of the robot each.
Then i operate the arms and other dohickies on the robot from a seperate and much more complicated joystick and button box....
It would be alot harder to have one person trying to operate our arm and drive at the same time but michael (onizuka) and i have really good communication and can work really well together...
its all a matter of practice...
I have seen some teams that do it all with 1 person but with a bot with an arm or a complicated device other then the drive train i think it would be better with 2 people
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 25-02-2003, 20:12
edomus's Avatar
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
Because we are a rookie team we decided to go really simple, and because of this everthing works great. We have 1 joystick for steering, and one for our lifting aparatis. all other functions are done by the buttons and triggers on there respective joysticks
Unread 25-02-2003, 20:16
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
not a very good idea having one person do everything.... we set up our 2001 bot for one person control and all it had was an arm that goes up and down, and that was confusing when you actually tried driving. theres reason they let you have a second operator, i suggest you use one
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 25-02-2003, 20:19
edomus's Avatar
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
we tried both ways but it in the end the robot worked much better when only I controlled it. My co-driver will deploy our secret weapon when need be but the actual operation of the robot for our design seems to work better with one person. I think this is because we did not have much time to practice and comunication was lacking.
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
We have 2 joysticks that control the drive, with buttons that do various drive aiding functions. Also, one button controls the tilt of the forklift vertical. Then the co-driver controls the grabber arms and the lifting mechanism, along with some other goodies. This allows the driver to have complete mobility around the field (because I can lower the vertical to go under the bar), while the co-driver can focus entirely on bin grabbing and stacking. But communication is key.
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 25-02-2003, 21:41
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
There are two of us on our team, and for as far back as I know, we have always used two. The first driver (Bob) has a joystick, and has complete control of the base. Included this year is the buttons on the joystick for shifting from 2wd to 4wd, and an auxilary box with a switch to shift high to low gears. The second driver (me) has one joystick to control the arm. In addition I have a control box that has appx. 8 or so different buttons; one for each possible 'mode' we can be in.
I would suggest trying to implement a plan to include a second driver, and keep communication as your key.
Unread 25-02-2003, 21:54
Mimi Brown's Avatar
Mimi Brown Mimi Brown is offline
#0128 (The Botcats)
Mimi Brown is an unknown quantity at this point
Send a message via AIM to Mimi Brown Send a message via Yahoo to Mimi Brown
2nd drivers are help out in more ways than one. It gives your team an extra set of eyes on the field, too. Or, they can help out as a 'secondary coach' type person as well.
GRADUATED!!! CLASS OF 03!!!
Is it intimidating that last year the most aggressive drivers in FIRST were two girls??
Main Driver, 2002 and 2003
team 128....THE Botcats
Winners of:
Team Spirit Award at WMR 2002, Judges Award at Pitt 2003, J&J Sportsmanship at WMR 2003
Unread 25-02-2003, 21:57
edomus's Avatar
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
that is the plan
Unread 25-02-2003, 22:04
Umm Errr...
we have 2 drivers. one has 2 joysticks for steering and footpedals for breaking (yes we have breaking but i can't give any more details than that). our codriver has another joystick that controls our lifter as well as our "wings"
1139 Alumni
Unread 25-02-2003, 22:13
edomus's Avatar
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
footpedals? nifty!
Unread 27-02-2003, 17:44
Dave_222's Avatar
Dave_222 Dave_222 is offline
I used to be cool.
AKA: Dave the Knaive
#0222 (Tigertrons)
Dave_222 will become famous soon enough
Send a message via ICQ to Dave_222 Send a message via AIM to Dave_222 Send a message via Yahoo to Dave_222
2 drivers like always. One joystick and one control box (cant tell you what for) for the driver and one control box and one joystick for the endeffector. pretty baisic but it works well and like everyone else here has said communication is the key.
"Get up and save yourself from youself."
Maynard
"Let me intorduce myself," the man said. "My name is Roosta, And this is my towel."
Unread 27-02-2003, 19:58
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Foot pedals while standing? That seems awkward... Why not just make a button on your board?
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
2003 IRI: A driver's last hurrah or a new rookie driver's experience? Amanda Morrison Off-Season Events 14 23-05-2003 17:39
Drunk Drivers MBiddy Chit-Chat 2 28-04-2003 00:52
drivers esellers Rules/Strategy 5 24-01-2003 08:46
Wireless camera ALLOWED as driver's aide? Travis Hoffman Rules/Strategy 7 19-01-2003 02:31
Driver's Controls 157#1Driver General Forum 22 23-04-2002 17:06
