Go to Post Don't start celebrating yet. I haven't a clue if we can get this working. - Kevin Watson [more]
Unread 09-09-2014, 11:29
sandiegodan's Avatar
sandiegodan sandiegodan is offline
FTC Mentor, FRC Inspector
AKA: Dan Glenn
FTC #10092 (Green.Griffins;)
sandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to all
[FTC]: Alliance Station Size
Has anyone found the dimensions for the Alliance Stations anywhere in the manuals or other documents?
I would like to determine the overall width of the field layout as compared with last year's diagonal orientation with the Drivers Stations located on adjacent sides. My sense is this year's field will require significantly more linear space as it faces the audience. Some smaller venues should start looking at this now.
Thank you,
Dan Glenn
2015-16 FRC Chairman, San Diego Regional Planning Committee
2016 FRC Inspector, Orange County (LRI), Los Angeles, Carson Division
2015 FRC Inspector, Inland Empire (LRI), Central Valley, Los Angeles, Galileo Division
2015 FTC Mentor 10092 Green.Griffins; R&D Robotics Education
2014 FRC Inspector, Inland Empire, San Diego(LRI), Archimedes Division
2012-15 FTC Mentor Team 6565 Stuffed Dragons & 8489 Green Griffins Boys and Girls Club
2013 FRC Inspector, Central Valley, San Diego(LRI), Los Angeles, Inland Empire, Galileo Division
2012 FRC Inspector, San Diego, Los Angeles, Central Valley, Newton Division
2009-12 FRC Mentor Team 1622 Spyder Poway HS
2007-08 FRC Mentor Team 2658 Pedestrian Rancho Bernardo HS
Unread 09-09-2014, 12:36
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
Re: [FTC]: Alliance Station Size
In past years, the station size has been 12 inches from the wall, and 42 inches wide. Now how long, its changed from year to year. By the drawings, it looks to be 10 feet long. They have not given a set number though.
Meaning a min. span of 21 ft.
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 09-09-2014, 12:42
Scott_4140 Scott_4140 is offline
FTC #4140 (Fish in the Boat)
Scott_4140 is just really niceScott_4140 is just really niceScott_4140 is just really niceScott_4140 is just really nice
I've looked too. The best I can guess is 3 feet x 10 feet centered on the side of the field and set back 1 foot. This is in part based on previous years Alliance Station sizes and locations and in part based on the only overhead view I could find on page 19 of the Field Assembly and Setup Guide. The view on page 18 supports a 42" deep area.
AndyMark has CAD for the full field out on their web page. Maybe there are more clues there.
Unread 09-09-2014, 14:52
AKA: Dan Glenn
Sounds like reasonable assumptions. The answer to my question though is I'm not missing it, it is not officially specified and we're going to have to ask the official Q&A or wait for a manual update.
The AndyMark STEP file is only of the tiles and tape inside the field. No documented record of the Alliance Stations.
Since there is a penalty for stepping outside of the Station, we'll have to have an official size soon. I'll work on the width of the fields for last year and see what type of increase we are looking at based on the assumption the Stations are the same as last year, just located at opposite sides.
I know several venues were tight for space including ours. This may drastically change plans to host or organize qualifiers if it is different enough.
Thank you,
Dan Glenn
Unread 09-09-2014, 15:29
Look at the Full_Field_V5.3_Full_Detail.STEP file. It shows the Alliance Stations. I only have a free STEP viewer and it doesn't seem to have a measurement tool. With my calibrated eyeball, it appears to be set back ~.5 tiles and be ~1.75 tiles deep. This would support the traditional setback of 12" and depth of 42"
That amounts to about 21 feet across. Add in a little more space for the FTA to get around the field. Should be close enough for you to gage space requirements for your qualifier.
Good Luck!
