| Thread Tools |
Rating:
Display Modes |
GCC 4.9 arm-nilrt-linux-gnueabi toolchain
Has anybody been able to successfully build a GCC 4.9 toolchain for the roboRIO? I've been looking into it, but I don't have any hardware, so I was wondering if any of the beta teams had had any success as of yet.
Re: GCC 4.9 arm-nilrt-linux-gnueabi toolchain
I have already successfully used 4.8.3 with it. 4.9 shouldn't be that hard.
What C library did you use? Just glibc? And where did you snag the kernel headers?
I have never cross-compiled before, so I am a newbie. When you use GCC and try to compile an application for another platform like the PPC in the cRIO, do you still have access to the full C++ STL library? Also, are there some libraries like pthread available?
I have the GNU GCC compiler to cross-compile for the RasPi, but I don't know if it will compile my application, which uses pthread and libx11. Thanks! |
One of my eventual goals is to set up Clang as well. |
We are currently updating our toolchain for GCC 4.9, which will (hopefully, almost positive) be the official C++ compiler for 2015. Its not yet done (I'm actually waiting for GCC to compile on launchpad as I type this), but we are hoping to let some beta teams test it soon (week or so?).
Shameless plug: Anyone interested in maintaining arm-linux-gnueabi packages for non .deb-based linux should contact me. If the given platform already has binutils 2.24 and gcc 4.9.1, you only need to package the header files and so libs. |
#7
EDIT: Also is there a preview version of wpilib i could be using? Last edited by CodeYeti : 08-09-2014 at 19:33. Reason: formatting |
#8
You should be able to use the Linaro GCC 4.9 toolchain on a Linux box. I'm using it now for my other ARM platforms on my Linux Mint 17 box.
#10
To get read access, I submitted an account creation request on the login page and it got approved by an administrator eventually.
#12
I'm still planning on rolling my own toolchain, but for the information of others I just found someone building Debian/Ubuntu packages here.
#13
While this might not be exactly what you are looking for, NI has a full openembedded build system set up as well as their fork of the linux kernel on their github here: https://github.com/ni
There are a couple of other cool things on their github as well if you look around. |
#14
Also if you are a beta tester and you haven't heard of this yet: we are rolling this out slowly due to the large breakage this could cause. Don't panic. |
#15
Excuse me for this extremely newbie question:
Just a couple days ago, I made an ARM cross compiler for my RasPi. They both are ARM based, so right away, it seems as though the RPi executables will be compatible with the cRIO. However, aren't there differences in the machine code between the different subsets of ARM? Would they prevent my executables from running? Thanks! I'm quite new to cross-compiling. I want to have a cross compiler ready for the RoboRIO so I can push my software as soon as possible! |
