Thread Tools |
Rating:
Display Modes |
Re: Team 254 Presents: Cheesy Arena
Very impressive! Huge thank you to everyone involved. Great to see it's written in Go as well
Pat, how'd you like implementing a real web service in Go? Any things you found worked well and things that didn't? |
This is absolutely fantastic. I'm not a programmer by any means, but I can tell that a ton of effort went into this, and even just from the CC webcast, it looked incredible.
Thank you for working so hard on this and for sharing it with the community. I really hope some of the pieces of Cheesy Arena transition into meaningful changes to the systems used in regulation competition. |
It seems that every couple years you earn a giant cookie. Great work, Pat!
-Nick |
Wow, looks great! I have one question: What is the protocol for feeding video to the audience display? This is my team's first time setting up any kind of fms software and we are unaware.
Thanks! |
Thanks again for all the hard work. |
#7
Is there any documentation as to the network interface used to control the pedestal and hot goal lights?
#8
We built some custom hardware (an embedded microcontroller board plus an LED driver board) into a project box and put one at each end of the field. We'll post the specifications for that on GitHub once the guys who worked on it finish documenting it. The communication was UDP over Ethernet -- just a plain 32-byte packet containing RGB and transition time values for each of eight channels. |
#9
Thanks for the description.
One at each end of the field connected to 3 USB monitors each.
#11
The monitors were a nice touch - what's the model you used?
#12
From what I saw (on the label from the back of the display), they used the AOC E1649FWU displays.
For their PC, they used some sort of Intel NUC that was attached to the display in the center alliance station. Pretty darn slick setup. |
#13
This was the first project I've used Go for so I struggled a lot with the non-object-orientedness and how to organize the code and minimize repetition. The final result isn't ideal and I need to keep working on it -- all the code is in the same "main" package, there's a lot of shared global variables, and the WebSocket handlers are more repetitive than I'd like. Overall, though, I'd highly recommend Go for any web service work. |
#15
According to the "What programmers say vs. what they mean" translation table below, I believe the expression you are looking for is "It's a 'Complex structure'". ![]() All kidding aside, we look forward to using Cheesy Arena at CCC next weekend. Let's hope we can use it as skillfully as it was used at CC. Thanks again Pat, and your team, for making this and sharing it! |
