Go to Post A winning robot is not a winning robot unless you have winning drivers too. You need the time to develop both. - Jim Zondag [more]
Unread 11-09-2014, 14:30
wgardner's Avatar
wgardner wgardner is offline
wgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to behold
[FTC]: 3D printable Samantha Bracket from AndyMark
Hi All,
I just stumbled across the link below, which has a freely downloadable STL file for 3D printing a Samantha bracket, complete with standoffs to support the module and its power and USB wires. Nice, and free! Thanks AndyMark!
http://www.andymark.com/product-p/am-sambracket.htm
CHEER4FTC website and facebook online FTC resources.
Providing support for FTC Teams in the Charlottesville, VA area and beyond.
Unread 11-09-2014, 22:27
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
Re: [FTC]: 3D printable Samantha Bracket from AndyMark
You can thank team 4251 for this. This is what they have been using for a while and they made a 3D printable version of it for other teams to use!
Unread 12-09-2014, 07:03
wgardner's Avatar
Yes, I found out from AndyMark after my post that this was the work of an intern from FTC4251. So thanks to FTC4251! I thought it looked somewhat similar to their previous Samantha mount at the link below:
http://www.instructables.com/id/Sama...cket-Assembly/
BTW, it isn't obvious at first glance from the AndyMark page, but the holes in the 3D printable bracket are spaced to match the Tetrix channel hole spacing.
Finally, one of the schools I work with only has a 3D printer with a 5 inch bed, so this 5 inch bracket is a little tight for that printer (especially with the traditional skirt around the part). I worked up a version that fits in a 4.6 inch square by rotating the original 45 degrees and slicing off the top corners of the original part. If anybody is in a similar situation, they can download this slightly smaller version of the bracket as an STL file at this link. The original is still better if your printer is able to print 5 inch parts.
Unread 13-09-2014, 01:08
Andrew Tucker
AKA: Andrew Tucker
Which printer are you using?
Unread 13-09-2014, 05:18
wgardner's Avatar
I think that one school uses an Afinia printer and they've added some perf board to make the prints easier to pry up after printing which slightly shrinks their effective print area.
Unread 13-09-2014, 08:07
wgardner's Avatar
FYI, I added the modified, 4.6" version of the bracket to Thingiverse here:
http://www.thingiverse.com/thing:461851
And I whipped up a mini-version inspired by the original bracket that ONLY has the standoff support. This is tiny and can be printed on even small printers. It doesn't provide full support for the entire Samantha though, just the cables. It's available at the following link:
http://www.thingiverse.com/thing:461955
BTW, FTC4251, another useful bracket would be one that simply and strongly connects the NXT brick to the newly allowed USB Surge Protector (shown on page 17 of the new FTC Robot Wiring Guide) with room for the small USB wire connecting them. Any chance you guys might want to design one of those?
Unread 13-09-2014, 09:40
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Both brackets do the job. Just remember that once you put the USB extension into the bracket, it's in there solid. If you use the Instructables version, use a gear hub or appropriate spacer to keep the risk of bouncing, which could break the USB port in the Sam. If you use the AM Printable one, make one for every module so you can swap it easier. Also helps to loan one to teams in need.
The Surge Protector in use will require a USB adaptor to go between the Surge Protector and the Extension. Wrapping all of this in some form of wire shielding is advised along with keeping cables short and being mindful of wire routing in your robot.
Good luck.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
