Go to Post If your goal is to win matches... Pick the most capable candidate. If your goal is to change lives... Sometimes you pick those that need the most change. - IKE [more]
Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Unread 10-09-2014, 16:36
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Re: FTC 2015 Challenge "Cascade Effect"
Originally Posted by Mr V View Post
It all depends on how you grab the bottom, look at the Robot in 1 Weekend machine, it will prevent it from tipping over if you are dragging it behind the robot.
We pulled a full 90cm goal up the ramp without it tipping, but know that the 90cm ones when they roll down the ramp (even empty) will usually topple over when they hit the matt. Sometimes the 60 cm one will tip as well.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 11-09-2014, 12:44
jdaming jdaming is offline
jdaming is on a distinguished road
Originally Posted by maths222 View Post
2. From the game manual:
Therefore, the 1st ball is only worth 6pts time its height. The game animation was poorly worded regarding the scoring. (90 cm is 100% irrelevant except for the difficulties it presents in placing balls, leading to a higher scoring multiplier.)
It also says in the scoring table listed on Page 7 of game Manual 2 "Balls Scored In (from floor) Center Goal".
Therefore the first ball would count for 120cm (top of center goal) - ~27.5cm height of center goal + height of ball (~7 cm big) = 100cm x 6 = 600pts.
I agree that this seems like a game breaking amount of points but I think the challenge of getting a ball scored at 120CM will be difficult. I am wondering why it is referenced both in the video and where I quoted above if counting from the floor is not the intention.
Someone please correct me if I have misinterpreted something.
Unread 11-09-2014, 15:16
Scott_4140 Scott_4140 is offline
FTC #4140 (Fish in the Boat)
Scott_4140 is just really niceScott_4140 is just really niceScott_4140 is just really niceScott_4140 is just really nice
The (from floor) reference is to remind teams that balls must first contact the floor before they are legal scoring elements for the rolling goals or the center goal. It has nothing to do with where the measuring begins.
See page 9, section 1.4.3 Driver-Controlled Period "Balls are legally able to be Scored once they have made contact with the Playing Field Floor." The end game is part of the driver controlled period so this rule still applies.
Several places within the rules, it quite clearly states, "points for each cm of Ball Height" or "Points per cm of Ball Height". This clearly indicates that measurements should be from the bottom of the lowest ball to the top of the highest ball. Limits are shown in the table for the rolling goals. Since the 30cm goal uses the same 27.5cm tape as the center goal, that would indicate a 27cm limit for the center goal. Expect clarification from the GDC on September 15th.
Unread 11-09-2014, 15:20
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
There is no way the GDC will allow for one ball to be 600 points. The GDC has learned over the years to expect the un-expected... (i.e. Bowled Over, when robots were lifting 18 ft in the air, when they thought a 5 ft stick would be enough)....meaning teams will find easy ways to score in the center goal...
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 11-09-2014, 21:32
Kpchem Kpchem is offline
FTA, CSA, and all things technical
AKA: Kevin Emery
Kpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to behold
The center goal, like the other rolling goals, have measuring gauges on them that start at 1 and go up from there. The measurement for height (and therefore scoring) is not done from the floor, but rather according to those gauges.
FRC 360: 2008-2011
Full-time Volunteer: 2012 - forever
Unread 11-09-2014, 22:42
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
Originally Posted by BBray_T1296 View Post
Though I have never been a part of FTC, here is what I see being a really competitive robot
On the back of the robot is a latch for grabbing onto the 90cm goal, never letting go, so the goal becomes a trailer being rigidly towed for the remainder of the match.
The robot has a continuous intake/lifting system that reaches up to the 90cm goal. Of course it will have to start 18cm and unfold/telescope to that height. This lifting system is similar to a conveyor belt (perhaps with brushes?) that takes balls from the floor, and straight up dumps them into the goal it has possession of.
If said mechanism is fast enough, you will be incapable of acquiring more than 5 balls at a time, because they will be spit out the top too fast.
This was one of the first ideas the team had. It's going to be the first design we prototype! I'll let everyone know how it goes.
Unread 28-09-2014, 16:16
totalreboot totalreboot is offline
FTC #8441
totalreboot is an unknown quantity at this point
what if you were farther from the goal? wouldn't the mechanism simply gather balls with nowhere to spit them out of?
Unread 28-09-2014, 23:35
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
If you had this vertical conveyor system, I would think you could start/stop it at will. If you didn't have a goal in your possession, you could simply hold onto the ball, like any other mechanism. Again, this was all theoretical. It is up to you to make it work.
