Go to Post I know that it's often dangerous to use common sense in a YMTC thread... - Kris Verdeyen [more]
Unread 12-09-2014, 15:51
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: Experience With 6 Cim Drive train
Our robot used 6 Cims this year. We used VexPro Ball shifters with total reduction being 5.5fps and 15.5fps. (<- not sure if accounting for inefficiencies). Our Drivetrain setup was a 6wd tank drive with 3" Colson wheels and non-cantilevered axles. It is worth noting our center of gravity was within 5" of the floor.
We played extensive defense all year. We tripped the breaker one single time all year, and that was playing at Texas Robot Roundup after 2 regionals, and a prior off-season event. During the season, we had absolutely no breaker problems.
I will try to dig up some video, if you would like.
For your questions.
-The battery was a few degrees above room temperature, the plastic casing was no hotter that a battery just off the charger. (When swapping robot batteries there was no thermal way of telling them apart from the casing)
-Our battery terminals are heat-shrinked and taped up so the metal itself is untouchable. I will say the whole lead assembly from the battery to the PDB was significantly warm, but you could comfortably leave your hand on them.
-We have never had any issues related to the battery connector, and, like I just said, these were also warm but not concerning.
We did not have any form of cooling; no sinks, no fans. After a match the back of the motor (where the brushes are) was too hot to touch for more than a second, but the rest was ok. (By the next match the heat had mostly dissipated). I think we will seriously consider some form of thermal dissipation in the future. We may put one of the large computer fans on the bunch of 3, or make our own heat sink. We do not find the heat sink the KOP had particularly useful, because like I said, it is the back of the motor that needs cooling, not the main casing. While those would help, the heat does not propagate that far to make them useful in my experienced opinion.
We did practice our robot for about 2 hours straight, with nothing but some 30 second battery changes every 5 minutes. By the end, you could easily boil water with those things, they were roasting.
Unread 12-09-2014, 18:44
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
We used 6-CIM ball shifters (with 2 CIMS and 1 MiniCIM each) on our robot this year. We had no problems with breakers when driving in low gear. There was one occasion that the main breaker was tripped during a hard collision in high gear that could have been attributed to a current spike (or just the force of the collision, we're not sure), but beyond that we had no issues that I'm aware of.
I'm hoping the current monitoring capabilities of the new PD board next year will make it really easy to manage current draw and maybe even allow us to program automatic down-shifting when current draw gets too high.
Unread 13-09-2014, 12:15
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
We had 6 cim single speed at 11 fps and were traction limited with versa wheels. Never tripped any breaker.
Just my opinion, but for the short duration of FRC matches, the low gears on 3 CIM gearboxes have way too high of reduction for robot movement (if the goal is preventing a breaker from tripping). However, if that slow speed is part of the design strategy of the game, that is a different story.
Those breakers can take some heat, let them get a little toasty, especially since FRC is held during the winter.
Unread 13-09-2014, 13:31
Professional Stat Padder
20 used a shifting 4-CIM, 2-MiniCIM drive geared for about 6 and 16 ft/s in 2014.
We loved it's performance for most of the season.
The only issues we had were when our driver forgot to switch into low gear when we were playing defense in our second qualification match at our first regional. We ended up tripping our breaker that match.
The gearboxes themselves took a lot of damage as well throughout the season, but that was because our driver drove the robot like he stole it.
(2015-Present)
Unread 13-09-2014, 13:50
Michael Hill's Avatar
I'm really excited for the new current sensing ability we'll have next year. It will let us automatically shift of we see too high of current.
Unread 13-09-2014, 15:46
I am Dave! Yognaut
AKA: Brian Bray
I certainly disagree with that. I find shifting to a low gear (<7fps) to be a very valuable asset, in more situations than just precise movement.
While our 5fps was definitely too slow to play the whole match in, there were numerous times (especially in the defense heavy game) that you just needed to knuckle down and bulldoze your way through a pileup. Our robot used 3" Colson wheels, had the bumpers at the lowest point, and had a center of gravity roughly 5" from the floor. We could push nearly everyone, and many tank robots saw themselves skidding sideways by us. We did not have a traction problem at that torque either, and our used wheels had little measurable diameter difference to new ones, to the naked eye.
Also, on the topic of generic shifting; Being able to change gears gives you the ability to have a high upper stage (like 16+). Many people had 18fps upper stages or more. If you had a single speed gearbox, I think most people would agree (game dependent, but for 2014 in this) that having only a 18fps gear would not have been a good idea. But certainly most people who had 18fps high gear shifters would agree that it was a great gear knowing you could summon the torque when you needed it.
Unread 13-09-2014, 18:13
Juan Martinez's Avatar
Juan Martinez Juan Martinez is offline
AKA: Fix This
FRC #0051 (Wings Of Fire)
Team Role: Driver
Juan Martinez is a name known to allJuan Martinez is a name known to allJuan Martinez is a name known to allJuan Martinez is a name known to allJuan Martinez is a name known to allJuan Martinez is a name known to all
This past year we had a 4 cim ,2 minicim vexpro ballshifter west coast drive and we were geared 18 high and 12 low fps we had absolutely no problems with popping breakers. We also had no problems with pushing in high gear although our engineers warned against. Our center of gravity was within 5 inches of the floor . The only thing that reached above 18 inches on our robot was the superlight floor intake and catapult in a nonshot position.
Unread 13-09-2014, 20:17
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Is this the gearbox you used? If so, how did you achieve a 1.5x spread?
Unread 13-09-2014, 21:54
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
1687 ran 6 CIMs single speed last year, at 14.5 fps, riding on colsons with a linear tread pattern, playing some real tough defense all year long. At our first event, we tripped the breaker once in our final match, at our second, a couple more times. After that, we looked for ways to eliminate breaker trips for our offseason events. Retrofit shifters were designed, but for various reasons, couldn't be manufactured in time. Instead, we made several minor mechanical, electrical, and software tweaks to reduce current draw:
  • Doubled the number of air tanks on the robot, reducing required compressor runtime
  • Systematically tested every pressure switch we own to find the one with the best combination of high cutoff pressure and low startup pressure, again reducing required compresser runtime
  • Switched our intake extension, our largest source of air use, to single acting pistons
  • Upped wire gauge in several places in the robot, reducing losses due to wire resistance
  • Coded our drivetrain to automatically drop to 4 CIMs when running our shooter winch or intake motors, with the driver given a trigger to override this in high-pressure situations
  • Added a trigger for our driver to shut off the compressor regardless of pressure during pushing matches
  • Added ramping to drivetrain which limited sudden accelerations and abrupt direction changes slightly
Did not trip the breaker after this. However, we do plan to use shifters in the future, or gear lower if the game does not call for the speeds we geared for this season.
Unread 13-09-2014, 22:07
Oblarg Oblarg is online now
AKA: Eli Barnett
Had essentially this exact same experience with a 6CIM SS geared for that speed. Instead of the measures described here, though, we simply changed our gearing to ~11fps. No more breaker problems after that.
"The breakfast of champions!"
Unread 13-09-2014, 22:24
Joe G.'s Avatar
AKA: Josepher
That wasn't an option for us because our gear box was constructed single stage and already pushing geometric limits for that configuration, our robot was not set up to accept a COTS single speed gearbox, and manufacturing our own wasn't an option for the same reasons as for shifters. That's the quick solution though!
Unread 14-09-2014, 01:57
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
I'm sure you already considered them, but in the event you didn't know about them, did you look at the 11 (or 13 tooth if you were running 14 tooth CIM pinion gears) tooth gears to drop in to replace the 12 tooth pinion gears?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 15-09-2014, 00:09
DarkRune DarkRune is offline
AKA: Dylan Baker-Flynn
FRC #4159 (CardinalBotics)
Team Role: Driver
DarkRune is a jewel in the roughDarkRune is a jewel in the roughDarkRune is a jewel in the rough
4159 used an amazing 6 CIM. Low of 7, high of around 17. The motors got hot during violent matches, and we tripped the breaker when we tried to push in high gear. Our low gear had an amazing amount of torque, we were able to 2-3 robots at a time no problem.
Unread 14-09-2014, 01:14
I am Dave! Yognaut
AKA: Brian Bray
Does this mean you were running (at least one pair of motors) in coast mode?
I suppose there probably isn't a huge difference between 4 and 6 brakes, so it doesn't matter I guess
Unread 14-09-2014, 13:12
Joe G.'s Avatar
AKA: Josepher
Yes, two motors were on coast.
We were running 11 tooth pinions at each of our events.
