Go to Post Ohh the [strike]humanity[/strike] robotity! - artdutra04 [more]
Unread 11-09-2014, 21:32
panther83 panther83 is offline
panther83 is an unknown quantity at this point
Exclamation Wiring a button for a solenoid on a T-shirt launcher HELP!
I am with a pre-rookie team from Washington Illinois and our first robot is a T-shirt launcher bot. We have the standard electrical board with 4 talon controllers going to 4 motors. All is controlled by an Arduino with Robot Shield, hooked up to a digital sidecar. Our problem is that we need a way to hook up a solenoid to our power distributor but also have a button wired into the PWM ports of the sidecar to distribute 12V of power to solenoid valve when pressed. I have no idea what to do but I do know how to solder, any help is awesome!
Unread 12-09-2014, 07:45
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
Re: Wiring a button for a solenoid on a T-shirt launcher HELP!
Though I'm pretty sure there are many ways to program this, on ours, we have a simpler solution.
On our t-shirt robot, we just use a model airplane-type servo that hits arm-type limit switches. We just have a two-barrel shooter, so all the way left, shoot left shirt--all the way right--shoot right shirt.
If you have more solenoids, you could progressively hit more limit switches the farther you move the servo.
And welcome to FIRST. you'll have a great time.
Unread 12-09-2014, 08:47
protoserge's Avatar
protoserge protoserge is online now
AKA: Some call me... Tim?
Can you provide a quick sketch of your pneumatics system with the part numbers of solenoids?
The simplest solution is to use digital pins on the Arduino to trigger a relay or MOSFET that switches 12V (or 24V) to your pneumatics solenoid "on" or "off". Depending on your setup, you may need two circuits. Here is a video that demonstrates this.
Unread 12-09-2014, 09:10
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Relay board from ebay.
http://www.ebay.com/itm/Four-4-Chann...em1e8c1c ff80
Video of our breakaway bot running on ardunio and robotopen
https://www.youtube.com/watch?v=jde3CIXQ8Jw
Edit: Just realized that the video was just driving, not kicking. Here is a picture of the completed control board with the relay board driving the solenoids.
http://www.mcbride4.org/?attachment_id=74
The sooner we get behind schedule, the more time we have to catch up.
Unread 12-09-2014, 19:00
The t shirt launcher uses compressed air from a 5 gallon air tanks which is fed to a reserve tank that goes to a modified sprinkler valve with a 1/4 in 12Vdc solenoid valve link- http://www.amazon.com/Electric-Solen.../dp/B00827FP26
Unread 12-09-2014, 20:21
DonRotolo's Avatar
Back to humble
FRC #0832
Here's the basic idea: Use a general-purpose digital output from the Arduino, which is 0 or 5 volts. Connect it to a relay (Radio Shack sells these; for example This One, but you should be able to find something locally. It's OK that it's 3 Volts, it's not that critical.)
The arduino controls the relay. The relay switches whatever voltage you want to the solenoid valve. Done.
