Go to Post Patience is a good strategy. - Koko Ed [more]
Unread 07-09-2014, 16:03
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
http://www.google.com/shopping/produ... 5502655880%7C
Unread 07-09-2014, 16:20
Re: Recommendations for chain drive lubrication?
Originally Posted by dradel View Post
Some of the commenters say they are using a solution containing water (yikes!) and degreaser (yikes!) in this product.
What cleaning solution do you use in this product?
Unread 07-09-2014, 17:21
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
I think you could run water and degreaser through it, then regrease the chain with the same machine.
Unread 07-09-2014, 17:32
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
That product is for mountain bike chains. Chains that live in a nasty environment, mud, water, & sand. It cleans the side plates & rollers. Typically a surfactant like simple green & water. You move the chain through it, no soaking. Being cheap, I just use a rag soaked in cleaner to the same effect. I have yet to see a FRC robot chain that dirty. Maybe for next years water & mud game?
Unread 07-09-2014, 17:35
dradel's Avatar
Head to local bicycle shop and pick their brains. I mountain bike for years and used both the park an the Pedro's machines dry. I used to use dry lubes on my chain to avoid dust and such from sticking. Personally if the chain was that bad I just replaced it, usually once a year sometimes twice.
Unread 07-09-2014, 17:54
So you disagree with comments below?
Originally Posted by hrench View Post
I don't support ever soaking a chain in solvent to clean it. You'll never be able to get the lube back to the crevices where it was.
Originally Posted by FrankJ View Post
I would avoid soaking chains in solvent. It leaches out the lubrication in the pivots where it is difficult to get back into.
Unread 07-09-2014, 18:20
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
No, I was just wondering if using a chain cleaner to do it would get the lube back in better.
Unread 10-09-2014, 12:09
dradel's Avatar
I the chain is really that bad replace it. #25 chain is relatively inexpensive.
Unread 13-09-2014, 07:45
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
I've been using the stuff in the link below for years on bicycle and motorcycle chains. It's very thin going on and flushes a lot of debris out of the links, then dries almost to a wax. Once dry, it stays put and is nearly dry to the touch. A can should last several seasons.
http://www.amsoil.com/shop/by-produc...?code=AMHSC-EA
Use it in a ventilated space, because it gives me an instant organic solvent headache until it is dry. YMMV.
