Go to Post Break Robot. Re-engineer. Repeat! - Mr MOE [more]
Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Unread 14-09-2014, 17:52
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
What is T-boning?
Now I know what t-bone is, Where a team collides with you on the side forming a right angle or a "T", but I'm not sure what is the effect is especially in FRC. Also I'm trying to understand how some teams avoid T-bones or get out of those situation. If someone could please explain and provide some examples of how team get out of these situation it would be much appreciated. Thanks!
2014 Dallas Semi-Finalist (Thanks 3847 & 231)
2014 OKC Semi-Finalist (Thanks 2341 & 2461)
Unread 14-09-2014, 17:57
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Re: What is T-boning?
The effect of T-boning is (usually) that your robot cannot move due to friction. Some team have countered this through slippery bumpers and unusual chassis shapes. The cheesy poofs use slippery bumpers and 971 uses a slightly angled chassis.
Unread 14-09-2014, 18:06
Sohaib's Avatar
Sohaib Sohaib is online now
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
Simbotics used drop down omni wheels this year to allow their robot to get out of T-Bones.
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
Unread 14-09-2014, 18:10
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
Actually T-boning in Frc isn't exactly where the robot can't move. It's where a robot pushes another robot that is moving forward/backwards on its side and the t-boned robot's wheels spinning and the sideways force from the other robot causes the t-boned robot to lose traction and then the defending robot can push the t-boned robot sideways. If the robot being t-boned does not move, the robot trying to t-bone won't be able to move it sideways because sideways force by itself isn't enough to overcome the traction of the t-boned robot.
Unread 14-09-2014, 18:22
AKA: Ahad Bawany
no team (None)
Interesting, never knew it could also refer to a case where the robot being 'boned is moved sideways. Thanks for the info!
According to 254, the alternate bumper material makes t-bones far less of a concern. They can just drive past them. I believe they use sail cloth for their bumpers.
Unread 14-09-2014, 18:37
Chris is me's Avatar
AKA: Pinecone
I think you're confused, because t-bone exclusively refers to when the robot being boned is moved sideways, or at least pushed from the side. Pins in general are not T-bones, nor is "wall defense".
Unread 14-09-2014, 19:28
AKA: Ahad Bawany
no team (None)
Oh I see. Sorry, I had previously thought that t boning referred to a t shaped pin! Thanks for the information.
Unread 14-09-2014, 23:12
Professional Stat Padder
T-boning can be a t-shaped pin. It can have the effect of the robot being t-boned moved sideways, or it can be against a wall.
T-Boning is generally creating bumper-to bumper contact with another robot with the front end of your robot pushing the other robot perpendicular to that robot's direction of motion.
The effect it has is often preventing motion in the desired direction, and thereby keeping the affected robot from scoring.
This can be better explained by someone smarter than me.
You can see it in most FRC matches this year that had effective defense.
(2015-Present)
Unread 14-09-2014, 23:37
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
What 1065 does to 233
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 15-09-2014, 00:13
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
T-bones are very hard to get out of especially when using mecanem wheels. The wheels have such little traction that you can't drive out of a t-bone like 254. Without using different bumper material or chassis, the best way is to have your driver get stuck in a few and then learn how to avoid them or drive spin or drive well enough to get out of them. I was caught in tons in the first district I drove and then was not caught in them hardly at all after. In my opinion the easiest way to avoid them is to be constantly moving. Also if you know that one is coming you can essentially spin out of it, if they do not hit you directly in the middle of your bumpers. Spin the corner the your robot the same direction that the robot is coming at you. Watch at about 1:04 when 3663 gets pinned by 1983.
https://www.youtube.com/watch?v=WbHHUtCGc1c
Unread 15-09-2014, 02:24
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
If you have your mecanum programmed properly and your drivers know how to take advantage of its holonomic capabilities i dont understand how you can possibly get t-boned. When somebody comes along side you all you need to do is translate away.
Team 1318: 2011-2015
Team 1747: 2015-Present
NAR (VEX U): 2015-Present
Unread 15-09-2014, 02:41
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
This.
Although not directly comparable, 33 this year was a good example of why having a low sideways cof could make it easy to slip out of t-bones. Given, this is all dependent on good driving, I'm sure it would have been easy to take advantage of 33's drivetrain when defending had they had poor driving ability.
Unread 15-09-2014, 13:46
AKA: Pinecone
Gearing is also important. You need to be able to apply force to the ground while your wheels are being backdriven and your rollers are spinning due to the pushing force. Ideally, you're right - translating away from the pin will allow you to escape. Just be sure to do some testing when implementing your mecanum drive as this kind of stuff can be hard to model accurately. Lots of factors involving play at the rollers, construction of the wheels, rigidity of the frame, etc. are at play.
Unread 15-09-2014, 14:02
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
There are a surprising number of mecanum robots that are not actually programmed to go sideways; they simply use mecanum wheels in a tank drive setup...
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 15-09-2014, 14:09
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
So like a normal omni-tank drive, but with 4 wheel independent gear-trains. Sounds expensive.
