Go to Post There are no simple solutions, as every solution has its own problems. - M. Lillis [more]
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Unread 15-09-2014, 10:06
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
Re: Best gyro for frc.
I had a opportunity to test several different gyros (from two different manufacturers) on an FRC robot for a personal project and like the others, I would recommend the Analog Devices gyros. The one I am currently using is the ADXRS450 (similar to the ADXRS453 above - except without the internal temperature compensation) and it works well. If price isn't an issue, higher quality gyros are available with some excellent specs, however they typically run more than $1000.
Mike
