| You may possess me without penalty. |
Re: Code not uploading
As others have said, your manifest file has the wrong name for your main class. This is most likely because you renamed your main robot class (often called RobotTemplate.java, or the one that extends IterativeRobot or SimpleRobot). If you remember the original name, you can just change the name of the class back to what it used to be, and it'll work again.
