Go to Post For those of us in the north, a water game turns into an ice game, which becomes Lunacy. And I don't think any of us want that. - Kimmeh [more]
Unread 17-09-2014, 14:15
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Lathe Tooling for Retaining Rings
Greetings,
We are working on a fall project and want to try out retaining ring of our axles.
We are using a 3/8" and 1/2" retaining rings. According to Mcmaster we need to cut a 0.029" and 0.039" wide grove in the shaft for them, but our lathe does not have a small enough bit. Do we need to grind a larger cutting tool down to size or can we buy a COTS items at that size, if so, where?
Thank you for your help in advance.
Unread 17-09-2014, 14:27
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Lathe Tooling for Retaining Rings
Here is a thread on grooving tools
Unread 17-09-2014, 14:28
Brandon Holley's Avatar
I have had abysmal luck with Mcmaster and grooving bits in the past, and I like to think of myself as pretty Mcmaster proficient.
MSC however has been a slam dunk for me, plenty of options:
http://www.mscdirect.com/browse/tn/I...navid=12107106
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 17-09-2014, 14:33
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
I use this system from Enco....see attached.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 17-09-2014, 22:02
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by wilsonmw04 View Post
.Do we need to grind a larger cutting tool down to size or can we buy a COTS items at that size, if so, where?
If you have a lathe, you should have some high-speed steel blank bits on hand at all times. Grind one down, using the tool tables to get the angles right, to the size you need. Yes you can buy one, but 20 minutes with the grinder and you're done.
Get "how to run a lathe", a book from South Bend Lathe, for example. Use copies on eBay are $15-20. Or the book from Atlas Press Co, maybe the same name, also about the same price. Both were first published almost a century ago, and are still completely valid. Everything about running a lathe is in there, in detail and plain language.
Unread 18-09-2014, 10:04
RoboChair's Avatar
AKA: Devin Castellucci
Everything you need, right here.
0.040 cut off blade ~$8
https://littlemachineshop.com/produc...gory=202639332
Cut off blade holder for a quick change post ~$22
https://littlemachineshop.com/produc...y=100520820 4
Quick Change post set (2 turning holders, a boring holder, and a parting tool holder) ~$90
https://littlemachineshop.com/produc...y=120649205 8
