Go to Post The strive for the Chairman's award is by far more important than the award. - Pavan Dave [more]
Unread 14-09-2014, 23:43
DarkRune DarkRune is offline
AKA: Dylan Baker-Flynn
FRC #4159 (CardinalBotics)
Team Role: Driver
DarkRune is a jewel in the roughDarkRune is a jewel in the roughDarkRune is a jewel in the rough
Gearing Mini CIMs
Hi guys,
My team's running a small scale build season in the off season, and we're going to be using mini CIMS for the pickup. The necessary ration is 20:1, but I haven't really dealt with gears before. Can any of you guys help me? Or point me in the right direction?
Thanks,
Dylan
Unread 15-09-2014, 00:35
TylerS's Avatar
TylerS TylerS is offline
AKA: Tyler Stark
FRC #1747 (Harrison Boiler Robotics)
TylerS will become famous soon enough
Re: Gearing Mini CIMs
A mini-cim is overkill for picking up and I am saying that from a team who used one for our pickup. That being the case I would recommend checking out vexpro.com and the VersaPlanetary or AndyMark.com and the Toughbox Nano.
Unread 15-09-2014, 00:49
That last depends on what is being picked up... That said, 310 RPM and 20ft/lb (the reduction result) is a stronger pickup than most, I'd say (and likely slower--a fast intake with a good grip and sufficient torque is better than a slow but way-too-powerful intake). Try the BAG motor (700 RPM and 5 ft/lb, as reduced) or a BaneBots motor, or use a lesser reduction. For an intake, I'd generally go BaneBots with a BB gearbox as having a smaller footprint and lower weight, and it's not terribly hard to get the right gear ratio for the pickup off of that gearbox if the gearbox isn't exact.
Unread 15-09-2014, 01:36
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Hi guys,
Thanks,
Dylan
Gear ratios are quite simple. To gear 20:1 you state for every 20 rotations of the input gear, you want 1 rotation of the output gear.
It is also true that for a single stage reduction (2 gears, one input, one output) the Output gear must have 20 times more teeth than the input. If the input gear has 12 teeth, the output must have 240.
240 teeth is a lot. If VexPro carried a gear that size, it would be a whole foot in diameter.* That is unrealistically big, and not surprisingly, they don't sell one.
What you will need is a 2 stage reduction. That is, 2 sets of gears that, in total reduces the rotational rpm by a factor of 20.
In essence, instead of having one ratio of 1:20, you have 2 ratios, let us say 1:4, and 1:5. The CIM enters the gearbox (let's assume 5000rpm for ease), and running through the first gear ratio, is reduced from 5000 by 1/4 to 1250RPM. That gear drives a shaft, and consequentially another gear, into the 5:1 gearbox. That 1250rpm gets a reduction to 250rpm, which, what do you know, is 1/20th of the starting rpm, thus a 20:1 ratio.
There are several combinations that can achieve this, such as 10:1 and 2:1, but the premise is the same.
For your application, another great option is a planetary gearbox. The internal architecture is different and hard to easily explain, but the same purpose is achieved. VexPro sells a very good customizable planetary gearbox set that will easily get you the 20:1 you are looking for, at a reasonable price, but you will have to slightly and permanently modify your motor to work in it.
There aren't a lot of options when it comes to non-planetary reductions reaching as high as 20:1. But here are 2 links to popular planetary gearboxes used in FRC.
The VexPro option, cheaper but requires some modification.
The Banebots option, more expensive, and doesn't have exactly 20:1 like you want, but requires no modification
Unread 15-09-2014, 13:45
Team Role: Driver
Sorry, I was distracted when I wrote the first post, I mean mini CIM for shooter, we're using a bag for the pickup. And yeah, I think I will be going for the 4:1 and 5:1 solution, thanks for the help.
Unread 15-09-2014, 14:09
What kind of shooter will you be using?
Unread 15-09-2014, 14:12
Team Role: Driver
Elastic powered catapult. Plan on pulling back the catapult with the motor, and using surgical tubing to fire.
Unread 15-09-2014, 14:43
How are you planning on holding the catapult in the pulled-back ready-to-fire position while you're waiting to fire?
Unread 17-09-2014, 11:38
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Excellent question, you can't let the motor burn up holding it in place. We used a ratchet and pawl attached to the big gear (kinda acted as a hub also) in our reduction.
Unread 18-09-2014, 07:20
Gdeaver Gdeaver is offline
FRC #1640
Actually you can use the motor to hold the surgical tubing pulled back. That's what we did this year. We used a cim but could have used a mini cim. Used the parts from a Andy Mark shifter and added one more reduction stage. Used a force sensor to measure the pull back force and a PI to hold at about 120 LBS of tension. The holding current was surprisingly low and the motor only gets slightly warm even after extended run times. Only problem is the Andymark dog design has very little contact and the dog and gear wear. They have to be replaced periodically. Benefit of the design is that we can just kill power and the ball is just released with out shooting. At the end of the match the shooter is not in a cocked state. good for safety.
Unread 18-09-2014, 12:18
I'm pretty sure Keith knows that, but the OP may not know all the conditions necessary for that approach to work: type of motor, amount of gear reduction, how much force on tubing, and in marginal cases how to take advantage of friction in the system (e.g. the difference between the torque required to pull the catapult back vs the torque required to hold it once it's there).
I was hoping to get a response from the OP. Based on the response, there probably would have been a follow-up dialog, leading to the discussion above.
Unread 18-09-2014, 12:54
Team Role: Driver
Sorry, we were planning on using a ratcheting mechanism, although what Gdeaver said sounds interesting, and I may end up trying that instead.
Unread 18-09-2014, 12:56
You still need a clutch to fire the catapult, right? If you time things right (cut the motor power a fraction of a second before releasing the clutch), you may be able to reduce the clutch wear.
Unread 18-09-2014, 13:04
Team Role: Driver
Yes, out initial plan was cutting the power to the motor right before we fire. Not quite sure yet what we will use as a clutch though.
Unread 18-09-2014, 21:02
Take a look at McMaster's ratchet and pawl setups, or maybe just some ratchet straps (take the ratcheting mechanism out of the strap, or leave the strap on and re-rig the mechanism to suit your design).
Now, the hard part is disengaging and reengaging exactly when you want to, but that's for your design crew to figure out. I got no ideas off the top of my head.
