Go to Post I should have gone to IRI years ago. - Richard Wallace [more]
Unread 17-09-2014, 23:59
nathannfm's Avatar
nathannfm nathannfm is online now
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
pic: Gold VexPro sprocket
Unread 18-09-2014, 00:15
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Re: pic: Gold VexPro sprocket
This reminds me of 2013. We used a press fit dead axle wheel assembly. To make assembly easier I put the shaft in a freezer and the sprockets on a hot plate, the sprockets would either get slightly lighter or turn a quite off putting green color.
It's worth noting that for aluminum to turn the color your sprocket did it needs to be heated to almost 2000F. Annealing aluminum on the other hand is done below 1000F. Just something to be aware of.
-Adrian
Unread 18-09-2014, 01:23
edited: nevermind, noticed grinding marks.
Unread 18-09-2014, 01:53
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
"Easier" is one way to put it. I seem to remember you quickly putting two sprockets, a wheel, and the shaft in alignment, pouring on some green loctite, and hanging off a 5 ton arbor press in order to press the assembly together. With about a 50% success rate...
Good times!
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 18-09-2014, 02:35
DampRobot's Avatar
Physics Major
AKA: Roger Romani
-Adrian
Is this because the chemical structure of the dye used in the ano changes at high temperatures, or because some kind of thin film interference varies due to head expansion between two layers?
-Plutarch
Unread 18-09-2014, 08:58
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
-Adrian
At 2000 F your aluminum has turned into a puddle & no longer looks like a sprocket. Maybe even so at 1000F depending on the alloy. Anyway 1000 will have killed any age hardening.
Unread 18-09-2014, 09:08
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I'm curious how you got the sprocket to hold its shape as the weld cooled - or was it a non-issue?
Unread 18-09-2014, 11:14
nathannfm's Avatar
AKA: Nathan
FRC #3940
I was not personally around for the welding but I don't believe they did anything special, nor did we instruct them to, and there is no warpage.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 18-09-2014, 13:34
Good catch, thanks! I got my metals mixed up, aluminum melts at ~1200F so disregard my previous comment.
-Adrian
Unread 18-09-2014, 14:46
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Let us know how it holds up now that you've removed most, if not all, of the heat treatment!
Was this a 6061 or 7075 sprocket?
Unread 18-09-2014, 16:05
nathannfm's Avatar
AKA: Nathan
FRC #3940
It is a #25 plate sprocket, VexPro specifies that they are originally 6061-T6 AL
I doubt we will see any wear as it is a prototype in an extremely low rpm application, but if something interesting happens I'll post it.
