Go to Post I didn't think it was possible for Dave to be any more cryptic. I was wrong. - IMDWalrus [more]
Unread 19-09-2014, 09:37
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Special Relativity, What The...
Usually I can read enough of a concept to understand it, but Relativity itself is something that baffles me. Time slows down just because you're moving? I get that information from a single point appears to slow down as you move away from it. Yet here's what doesn't make sense to me:
Indeed, if you put an atomic clock in an airplane and fly it around the world, it will end up with a slightly different time than an identical clock that remained at the airport.
How can the time of flight for the clock on the plane be different from the time of flight for the clock on the ground, given that both went tick-tock for an identical length of time?
And doesn't this imply that photons may have an infinitesimally small lifetime if they were to stop moving?
Can anyone shed some light on this?
Article
Maybe I should just stick to software...
Unread 19-09-2014, 09:55
Re: Special Relativity, What The...
In a vacuum, photons are always moving at the speed of light.
Unread 19-09-2014, 10:03
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
A frictionless vacuum that is.
Unread 19-09-2014, 11:58
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Frictionless vacuums are best vacuums.
Speaking of infinitesimally short lifetimes...http://xkcd.com/669/
Hi!
Unread 19-09-2014, 14:48
Aren Siekmeier's Avatar
on walkabout
As Ether pointed out, a photon can never "stop moving." However, if you were to "attach a clock" to the photon and watch the clock as the photon went by, you would see that the clock is frozen. In fact these two things are related by the theory.
Unread 19-09-2014, 15:27
Bob Steele's Avatar
AKA: Bob Steele
The constant is the speed of light... not the time. The time is relative.
Unread 19-09-2014, 15:43
To whom were you responding?
Unread 19-09-2014, 15:48
Michael Hill's Avatar
This class is very good at teaching special relativity: https://www.youtube.com/watch?v=BAurgxtOdxY
Unread 21-09-2014, 12:09
Bob Steele's Avatar
AKA: Bob Steele
JesseK
Unread 21-09-2014, 12:51
JesseK
OK.
It was a bit confusing, because your post is linked to compwiztobe's post#5, so it appeared that you were commenting on his post.
Unread 21-09-2014, 17:23
GCentola's Avatar
GCentola GCentola is offline
Strategical Tactitian
AKA: Garrick
no team (SparX)
GCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud of
http://www.testtubegames.com/velocityraptor.html
GO SparX on 3!!!!!
Check us out at:
http://www.gosparx.org
http://www.facebook.com/SparX1126
I Love Two Pencil Designs!
Unread 21-09-2014, 19:13
Someone zips by you at 90% of the speed of light. You say his watch is running slowly because he's going so fast...
...but from his perspective, you zipped by him at 90% of the speed of light. So he says your watch is running slowly.
Unread 22-09-2014, 09:39
JesseK's Avatar
FRC #1885 (ILITE)
Say the time of flight was 1 hour according to the airport. What does the air traffic controller say? Do the planes have to make relativity-induced adjustments for landing upon approach? Did the pilots age more or less than one hour during the flight, relative to the air traffic controller who aged exactly one hour? Age is very perspective-based, which is the only reason I bring it up here.
The video helped a lot with defining the inertial frames of reference Michael, thanks for the link.
Unread 22-09-2014, 10:09
For a one-hour flight at 500 mph, the pilot would be about 1 nanosecond younger.
