Go to Post Like his father, John V-Neun will soon have the advantage of his head resembling a game object. - Eric O [more]
Thread Tools Rating: Thread Rating: 20 votes, 5.00 average. Display Modes
  #46   Spotlight this post!
Unread 20-04-2014, 15:00
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Re: cRIO 2015 : NI roboRIO
Originally Posted by cadandcookies View Post
, I'd almost say the STEP version is better, as it imports as an assembly with the pins as separate parts from the body, which is nice for doing wiring in Creo.
Let's go with the STEP model. I'll ask that we add a note on the site about file compatibility.
  #47   Spotlight this post!
Unread 24-04-2014, 17:13
iKiel2012 iKiel2012 is offline
FRC #1073 (The Force Team)
Team Role: Electrical
iKiel2012 is an unknown quantity at this point
The 2CAN is also integrated into the roboRIO
  #48   Spotlight this post!
Unread 24-04-2014, 18:16
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Not exactly.
A separtate CAN interface is included on the RoboRio. It is a 2pin signal connector and the roborio has a built in can terminating resistor.
2CAN is not on the Roborio. 2CAN is a standalone product of CTRE.
Regards,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
  #49   Spotlight this post!
Unread 28-04-2014, 17:05
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
The Power Distribution Board has the termination resistor, not the RoboRio.
  #50   Spotlight this post!
Unread 28-04-2014, 17:12
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
You need a termination resistor on BOTH ends of a CAN network to make it work. The RoboRio has one built in, always connected. The Power Distribution Board (at least the revision the Alpha Testers got) has one built in, connected through a jumper so that it may selectively be selected as the other end of the chain.
2016: Lake Superior WFFA
  #51   Spotlight this post!
Unread 28-04-2014, 17:19
Controls Engineer
AKA: Kevin
Not true.
For Controller Area Networks (CAN) to work properly, both ends of the bus need to be terminated.
This is because communication flows both ways on the CAN bus therefore both ends of the pair of signal wires (CAN_H and CAN_L) must be terminated.
The RoboRio has an internal terminating resistor that can not be removed. This means the RoboRio should always be at one end of the CAN Interface. The PD Board, has a setable terminating resistor by way of a jumper, this means the PD Board can be used at the other end of the CAN interface if the jumper is in place. However, the PD Board does not have to be at the end of the bus, you can remove the jumper and put another device after the PD Board, just make sure to add a terminating resistor to that device.
Hope this helps,
Kevin
  #52   Spotlight this post!
Unread 28-04-2014, 19:15
One Eyed Man
My mistake. Still learning about the equipment.
  #53   Spotlight this post!
Unread 28-04-2014, 19:27
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Great, thanks!
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
  #54   Spotlight this post!
Unread 20-09-2014, 10:12
jt_999 jt_999 is offline
FRC #0999
jt_999 is an unknown quantity at this point
Does anyone know if the roborio is REQUIRED for the 2015 season, or will we have the option to continue using the cRIO for a year or two?
  #55   Spotlight this post!
Unread 20-09-2014, 10:33
It will be required.
The cRIO's will still be compatible and can be used for practice robots.
  #56   Spotlight this post!
Unread 20-09-2014, 23:27
adammiller3122's Avatar
adammiller3122 adammiller3122 is offline
FRC and FTC Mentor
AKA: Adam Miller
FRC #3122 (The Alluminators)
adammiller3122 will become famous soon enough
Do you have a source for the cRios still being compatible because when I emailed FIRST, they said that they could not tell me because it would be disclosing software information for the new season.
Adam Miller
New Ulm Robotics - Alumni
FRC Team 3122: The Alluminators (mentor)
FTC Team 8005: Robot Renegades (mentor)
homepage: newulmrobotics.com
  #57   Spotlight this post!
Unread 21-09-2014, 07:52
That FIRST answer addresses the question of legality under the 2015 rules which of course cannot be commented on before January 3, 2015.
We don't know what will be REQUIRED by the 2015 rules until January 3 when the rules are released for the first time to everyone at once.
There are no previews for individual teams via questions or otherwise.
So while neither I nor anyone else KNOWS the 2015 rules, I deduce that FIRST giving everyone a new control system in the Kit-of-Parts means that we will all be using it.
This is the 8th control system that FIRST has introduced. Every control system changeover in the past has completely replaced the previous system. I imagine this is because the old systems do not support the new capabilities and methods used for competition play. The systems only work together if the new system is degraded to operate under the limitations of the old system.
We're a Beta team.
One of our tests is that the new software still supports the old cRIO system.
P.S.
The Beta 2015 control system is actually being tested in some off-season events and it works fine alongside the old cRIO systems. However, setting up the communications means the mDNS system used by the new control system has to be disabled and the IP addresses hardcoded like the old system, and the new system has to be switched to use the old communication protocol.
  #58   Spotlight this post!
Unread 21-09-2014, 10:11
dawonn's Avatar
dawonn dawonn is offline
AKA: Dereck
FRC #2586 (Calumet Copperbots)
dawonn is an unknown quantity at this point
Has the programming software for 2015 been released to the public, or only the beta teams?
Is there any way to set up eclipse to program the old crio with java so that we can start getting familiar with the process?
Would any beta teams be able to post a YouTube video showing off the java programming environment?
  #59   Spotlight this post!
Unread 21-09-2014, 11:31
I suggest reposting your Java specific question in one of the Beta team threads on CD., like this one: 2015 Beta Testing - The Components are Here.
The software is with Beta teams only under an NDA, because we're verifying that everything works as expected and helping to refine the user documentation. We're creating bug reports and the FIRST/NI/CTRE groups are generating fixes.
General teams will get the final software in the 2015 KOP along with the hardware it runs on.
I'd check to see what Java Beta teams are closest to you. They will be doing workshops that you can attend and see the programming environment for yourself.
