Go to Post It's still not about the robots. FIRST is about doing the right thing. - DonRotolo [more]
Unread 20-09-2014, 20:21
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
TogetherSword8 is an unknown quantity at this point
FIRST Technical Contacts
I am going to contact FIRST with a problem that i have discovered on my robot that provides a serious safety issue.
I am planning on emailing frcteams@usfirst.org, but before I do, I would just like to know if anyone actually checks this address, or if there is somewhere else I should be sending this to.
It involves the compressor running in normal functionality when the robot is turned on at any point, which includes no computer connection to the robot and the robot being disabled.
I do not know the cause (nor would i like to speculate here) but I would like to contact someone at FIRST because the FPGA (which no teams have access to) is the component that should prevent this from happening.
I program a robot. Which means I write code and everyone gets mad at me when something doesn't work, even if I am the only one that knows it doesn't work. The key part to know is that the robot never works.
Unread 20-09-2014, 20:26
Michael Hill's Avatar
Michael Hill Michael Hill is online now
Re: FIRST Technical Contacts
Are you 100% sure there's not a wiring problem? Please post pictures.
Unread 20-09-2014, 20:29
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
Can you describe your wiring? I suspect it is wired improperly or a faulty relay is the cause as opposed to something FIRST needs to be contacted about.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 20-09-2014, 20:38
We are sure it is not a wiring problem, as we have measured the voltage coming out of the pins directly on the sidecar.
Unread 20-09-2014, 20:40
If you have a second Sidecar, then I would plug that in temporarily to see if the issue is a short circuit inside the DSC.
I've seen that cause this before.
Unread 20-09-2014, 20:41
I have seen a few digital sidecars where the relay enable signal is stuck in the enabled state. This causes the FPGA disable signal to be ineffective. Does your issue occur with another digital sidecar?
