Go to Post Ask two different FIRSTers for an opinion, get three different answers! - pfreivald [more]
Unread 21-09-2014, 15:55
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
Re: pic: Hex Bearings
Originally Posted by T^2 View Post
Both bearings failed as part of the polycarb intake arms. The second one, in particular, was fresh, and failed in its first match. 1678 didn't have any problems with these bearings throughout the 2014 season.
Where in the polycarb arms were they? Do you know what particularly in the match caused these? It sounds like it was a particular impact or something, rather than a life issue.
I guess I am surprised that after all you put that robot through this season, that you just had 2 failures in close succession.
I am curious as to the details so that we can learn from them for next year.
Unread 21-09-2014, 16:07
T^2 T^2 is offline
FRC #5499
They were both in the rear arm, on the end opposite the gearbox. (The second replaced the first.) From what I saw from the stands, neither failure was immediately preceded by any sort of contact with another robot.
Unread 21-09-2014, 16:12
Aren_Hill's Avatar
Build Nifty Things
You guys have such fun timing,
These guys will be in stock soon (bigger inner race).
-Aren
A guy who likes robots.
Unread 22-09-2014, 05:44
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Looks like the weight went down very slightly. What else is different? Smaller balls and more of 'em?
Richard Wallace
since 2003
Unread 22-09-2014, 10:33
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The bearings get used on drive trains without that kind of failure. It seem the drive train would have a higher loading. I am a little hesitant to blame this on bearing quality. Maybe the shaft is bending or severely misaligned which is torquing the bearing rather than a axial load?
Unread 08-10-2014, 16:39
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
I actually disagree... seems like the intake would actually likely have significantly higher impact loads (but probably smaller steady, radial loads).
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 09-10-2014, 01:26
JackFisher's Avatar
JackFisher JackFisher is offline
JackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud of
On our drive trains, we have shattered these hex bearings two seasons in a row. Its great that vex has a redesigned option now. The part of the bearing that failed on our drives was the corner where the steel was a bit thin due to the hex.
Unread 09-10-2014, 01:38
AdamHeard's Avatar
Lead Mentor
We didn't break any in 2013, we just broke so many this year it seemed like both years!
Unread 09-10-2014, 08:28
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Are the Vexpro V2 hex bearings the same as andymarks HD hex one? There is a fairly significant price difference.
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 09-10-2014, 10:03
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
-Ronnie
I have a feeling they are not.
Unread 09-10-2014, 10:22
Andrew Lawrence
Posts: n/a
Both are improved hex bearings with what seems like similar if not the same improvements. You can look at and compare the new AM Hex HD bearing thanks to Richard Wallace's post here with the new VP Hex bearing V2, found on their website.
If I were to guess I would say the price difference is based off of where the bearing is manufactured. Still, I'd rather just use round bearings.
Unread 09-10-2014, 10:29
For reference, the pdf image that I posted in another thread comparing old and new 1/2 inch hex FR8 bearings showed parts from AndyMark. The HD bearing is one that I ordered a couple of weeks ago, while VexPro was out of stock.
By my measurement, the inner race outside diameter of the AndyMark HD bearing is 0.76 inch, which matches the value shown under the heading "Hex Bearing Update" at the bearings page of the VexPro web site.
edit: I see Andrew beat me to one of the points above. To add a technical point, it makes sense that AM and VP would arrive at the same inner race outside diameter for more durable R8 hex bearings. This is because the improvement requires decreasing ball diameter, and bearing balls come in discrete standard diameters. So it is very possible that AM and VP are getting similar bearings from different sources.
The price difference will sort itself out. Markets are wonderful things.
Richard Wallace
since 2003
Unread 09-10-2014, 12:41
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Except for when you order hex bearings on AndyMark and get shipped VexPro hex bearings inside a VexPro package inside an AndyMark package. True story.
Unread 09-10-2014, 16:42
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I still can't believe that actually happened.
Unread 09-10-2014, 16:46
wilsonmw04's Avatar
Coach
Agreed, where's the trollooollloll?
