Go to Post It's not about the numbers, it's what you can do with them. - AlecMataloni [more]
Thread Tools Rating: Thread Rating: 15 votes, 4.93 average. Display Modes
  #76   Spotlight this post!
Unread 19-09-2014, 14:10
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Team 4095 Presents: iPhone Driver Station!
Originally Posted by raystubbs View Post
This meets your needs, but it is for android not iOS: https://play.google.com/store/apps/d...tdriverstation
Which mean's it doesn't meet my needs
It's awesome that people are developing for both platforms... we just need to see full features available for both!
2016: Lake Superior WFFA
  #77   Spotlight this post!
Unread 21-09-2014, 22:27
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
Originally Posted by Jon Stratis View Post
Is it possible to add some customization? For example, I'd like to be able to put two joysticks on the same screen - last year's robot had mecanum wheels, and required two separate joysticks for driving input, and the mechanisms were controlled through a spread of buttons between the two. Being able to select, for example, which axis on which joysticks the two pads represent and which buttons are available on the screen would mean we could drive from both the iPhone and driver station without needing to switch code.
Are you saying you want two MORE joysticks, because there are already two joysticks on the one screen...?
  #78   Spotlight this post!
Unread 21-09-2014, 23:35
Mentor, LRI, MN RPC
What you supply on the screen is the X/Y and X-Hat/Y-Hat form a single joystick (aka the joystick and the little guy on top you can move with your thumb). I want to be able to use the X/Y from two different joysticks on the same screen, I personally don't really care about the hat, we never use it (in fact, we haven't used a joystick with a hat since the IFI control system!).
Put another way, the app provides joysticks to match a gamepad, like an xbox controller. However, we use two actual joysticks (specifically Logitech Attack 3 joysticks).
  #79   Spotlight this post!
Unread 21-09-2014, 23:54
DarkRune DarkRune is offline
AKA: Dylan Baker-Flynn
FRC #4159 (CardinalBotics)
Team Role: Driver
DarkRune is a jewel in the roughDarkRune is a jewel in the roughDarkRune is a jewel in the rough
I'd like to see tank drive integration for this since it is a pain to keep switching between joysticks and having to drive in an s pattern. Otherwise I love the app, makes demos much easier.
  #80   Spotlight this post!
Unread 23-09-2014, 13:54
Ya our team doesn't use two separate joysticks, we use an xbox controller thats why I was confused, but I will definitely add support for two separate joysticks in the up and coming version!
  #81   Spotlight this post!
Unread 24-09-2014, 00:01
Team Role: Driver
Thank you so much. So both joysticks will be X/Y? That would be so helpful
  #82   Spotlight this post!
Unread 03-10-2014, 21:18
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Feature request!
Could you make a configuration using the iphone accelerometer such that the X-magnitude of the accelerometer maps to Joystick 1's X-axis, and the Y-magnitude maps to Joystick 1's Y axis?
That way you could drive the robot based on the phone's orientation.
I realize this can be dangerous, so I'd think it should require holding down a button on the screen to enable, otherwise disable (if the phone was dropped, etc).
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
  #83   Spotlight this post!
Unread 05-10-2014, 22:13
This is already implemented! Joystick 4 is for the accelerometer, x = axis 1, y = axis 2, z = axis 3, and it also detects if you drop your phone and disables the robot! So ya!
  #84   Spotlight this post!
Unread 05-10-2014, 22:33
OK, the updated version is now being verified by apple, it should be out within less than a week!
Also check back soon because when it gets approved I will be giving out a free download!
  #85   Spotlight this post!
Unread 08-10-2014, 00:27
So the new version 1.3 available here includes the two separate joysticks!
Here is a promo code for the first person who reads this!
YPYPTTJX7M7L
So please tell your teammates about this app so they can run the robot and have fun with it without setting up your whole driver station!
  #86   Spotlight this post!
Unread 08-10-2014, 01:14
mman1506's Avatar
mman1506 mman1506 is online now
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
YPYPTTJX7M7L
Yay, thank you. The app has been a godsend for last minute demos or even just moving the robot around.
2016: FRC 865 Mentor
  #87   Spotlight this post!
Unread 08-10-2014, 02:08
icecube45's Avatar
icecube45 icecube45 is offline
Drive|Programming|Captain
FRC #0114 (Eaglestrike)
Team Role: Driver
icecube45 is a jewel in the roughicecube45 is a jewel in the roughicecube45 is a jewel in the roughicecube45 is a jewel in the rough
Is there any way for this new version to support ios7?
  #88   Spotlight this post!
Unread 08-10-2014, 09:39
Mentor, LRI, MN RPC
Loaded it up for the first time with my new iPhone 6 Plus, and landscape mode isn't really working. When I rotate from portrait to landscape, everything squishes onto the left half of the screen, with the buttons overlapping the joysticks. This makes it pretty much impossible to use in landscape - my right thumb isn't long enough! To get it back in portrait mode, I have to switch to the Status screen, rotate it, then switch back to the joysticks screen.
Also, for the new tab with Joystick 1 and 2, which buttons are present? It just labels them 1-6, but I don't know if those are for Joystick 1 or 2... ideally, I'd like buttons for both joysticks available.
  #89   Spotlight this post!
Unread 08-10-2014, 17:14
Well unfortunately I do not have a 6 plus, it seems to work in the 6 plus simulator so idk why it wouldn't work on your phone...? Did you update to the latest 1.3 version?
Also with the buttons they all go to the first joystick, I was thinking about having three and three for each joystick but I forgot before I uploaded the update...
  #90   Spotlight this post!
Unread 17-10-2014, 15:28
The iPhone Driver Station is FREE for a limited time only!!!
