WCP DS or Vexpro BS?
Last season we used the 3 cim BS from vexpro, we loved them. We really only have one complaint; over the course of the season, we noticed more and more sag. We DID have a cross support between both transmission also. It wasnt that big of a deal..until we noticed scrape marks on the bottom cim from dragging. But we are looking into the WCP 3 cim DS, what are peoples pluses and deltas? From when you first got them till after a full season.
-Ronnie |
Re: WCP DS or Vexpro BS?
We also swapped the encoder gears for the replacement ones as the originals were slipping. With those two modifications we've never had to touch them through six competitions and hours of demos and they have been the most reliable two speed gearboxes I have used. I did notice some scrapping on the bottom CIMs however I don't believe it was caused by the gearbox sagging as the rest of our lexan bellypan (which sits lower than the CIM) is also covered in scratches. We did span between the gearboxes using some AndyMark Churro tube. Something to keep in mind is with a 3 CIM shifting gearboxes it is a lot more weight your are suspending off the side of your drivebase that can bend overtime and cause the sagging. When we were originally deciding what to use we were debating between the WCP 3 CIM SS, WCP 2 CIM Shifters, and the VP 3 CIM Ball Shifters. We knew in a defensive game we wanted a high and low gear which eliminated the single speed. We liked the Ball Shifter because it was an enclosed unit and the final factor was the fact that the VP 3 CIM Ball Shifters were $50 cheaper than the WCP 2 CIM Shifters (which is why we weren't even considering the WCP 3 CIM Shifters). When purchasing over $1000 in gearboxes for two robots, saving a few hundred dollars was nice. Last edited by BrendanB : 21-09-2014 at 19:11. |
For an COTS option there isn't anything else I would do. |
-Ronnie |
It is more common in a tradition West Coast Drive for the transmission plate to be bolted in contact with the 2x1 frame rail on one side with the bearing block on the other. That being said it can be done with a block on both sides if you really want to, but you'll have to have some good reasoning for doing so.
Hmm, Ronnie are you referring to the Ball Shifter with your question or the WCP shifter?
The WCP products are designed to house the sprockets between the plates Single Speed Assembly in WCD configuration Dual Speed Assembly in WCD configuration The Ball Shifters are completely enclosed, so the sprockets need to be on the outside of the gearbox and also have some spacing away from the chassis rail itself. If you can solve that without an inner bearing block in the rail, then you don't need the inner bearing block. Generally speaking, a single shaft should only be loaded between 2 precision bearings. The more bearings you add, the more chance the bearings are precisely lined up in their mounting leading to inefficiencies. The WCP gearboxes use only two bearings on the output shaft - one is on the inner gearbox plate, the other is on the outer bearing block (there is no inner bearing block). Spacers on the hex shaft keep the sprockets in place along the axle. This allows the outer plate of the gearbox to be direct-mounted to the chassis rail as Andrew described. Thus I believe if you're asking about the Ball Shifter, your question can be reduced to whether or not you can replace the bearing on the output shaft with a spacer, and then move that bearing to the outer bearing block. In theory I see no problems with this, yet I also don't know how the Ball Shifter is mounted. I only know this because I did some pretty thorough research on the WCP SS gearbox in WCD configuration since it's the only WCD-designed gearbox that VEXPro has in stock at the moment and we want to prototype something this Fall. Last edited by JesseK : 22-09-2014 at 10:09. |
#7
All we used for mounting was 4 bolts that attach the 3rd stage to the main gearbox with the axle extending across to a bearing on the opposite plate. The plate the gearbox mounts to has a cutout that allows the gearbox to be removed from the underside of the robot without having to slide the entire gearbox into the center of the robot (slide it out of the bearing on the far plate and it comes right out). The blue and red parts are just PVC spacers to keep the wheels and chains lined up. We color coded them blue (0.25in) and red (0.55in) so between two robots all spacers are the same and easy to identify. You can see the cutout I'm mentioning where the red spacer on the middle wheel meets the gearbox. Picture 1 Picture 2 |
#8
I haven't seen one but I feel like I show throw up a cad model I have of a COTS WCD. To use the versa rails with the DS it's basic drilling/boring. You need to make precise-ish slots to use the WCP WCD Bearing blocks, or just a big hole if you want to do go with the versa bearing block. If you are unfamiliar with the nitty gritty details of building a wcd look around on CD and you will find lots of information. As with everything there is a right way to do it, and a wrong way to do it. Last edited by Mk.32 : 23-09-2014 at 04:30. |
#10
http://www.vexrobotics.com/vexpro/we...gblocks-g.html http://www.wcproducts.net/wcd/ Paul |
#12
haha |
#13
Our white paper on building a belt driven Vexpro VersaChassis with 3 SIM ball shifter may be helpful.
http://www.chiefdelphi.com/media/papers/3050 |
