Go to Post it's not because the kids look up to him that [Dave] gets picked on, it's really because it's just so much fun. - MissInformation [more]
Unread 25-02-2003, 22:25
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
pneumatics
is it legal for an air cylinder to be manually powered by a motor in order to build up pressure?
Unread 25-02-2003, 22:59
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
not sure howya would do that, but the answer is no.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 25-02-2003, 23:06
edomus's Avatar
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
why would it be illegal. all it would do is push the shaft into the air cylinder
Unread 25-02-2003, 23:12
Clanat Clanat is offline
Custom Title
#0753 (High Desert Droids)
Clanat has a little shameless behaviour in the past
ask on the FRC forumes
Former Co-Captain
Winner NW Regional 2002 and 2003
Unread 25-02-2003, 23:16
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
Rule M11 states
Energy stored by FIRST Robotics Competition robots, i.e., stored at the start of the match must come solely from:...
Compressed air stored in the pnuematic system, but only supplied by the pump included in the kit and stored at a maximum pressure of 120 PSI
There you have it, air pressure can only be made through the pump int he kit.
Unread 26-02-2003, 00:25
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pneumatics
I think you would need a one way valve for that to work. Even if you could make it, I'm not sure if they would allow it though. They do allow creating a vacumn by manually extending or retracting a cylinder with a motor.
Unread 26-02-2003, 01:05
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Unfortunately, you're never going to be able to get more than 60psi using the kit parts. The regulator they gave us is a "relieving" regulator, meaning it won't allow the working pressure to go above 60psi even if you compress a pressurized cylinder. Since FIRST doesn't provide one-way valves, there would be no way to isolate the cylinder from the regulator either.
Unread 26-02-2003, 06:59
edomus's Avatar
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
"They do allow creating a vacumn by manually extending or retracting a cylinder with a motor."
is there a rule to show me this? Because this is exactly what I wanted to hear.
Unread 26-02-2003, 10:40
It was in a team update some time ago. Check hyperrules or the first website.
oil for for Pneumatics nragod Pneumatics 8 03-02-2003 22:30
Programming PBASIC for pneumatics archiver 2001 2 23-06-2002 23:58
PNEUMATICS PLEASE HELP archiver 2000 1 23-06-2002 23:06
pneumatics tank archiver 2000 2 23-06-2002 22:43
Filling the pneumatics tank archiver 2000 4 23-06-2002 22:43
