Go to Post The major items of FIRST are still what they always were.....understand the game, build a reliable quality machine to play it, train you drivers to use it to its full potential. If you do these things, you can win with or without any specific machine feature. - Jim Zondag [more]
Unread 22-09-2014, 17:14
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
Looking for slip rings and distributors
Our team is attempting to do swerve drive this year and we are looking for some slip rings but having troubles finding appropriate ones. we need 2 40A lines for a cim and 3 signal lines.
What slip rings does your team use(if any) and where do you get them from?
Unread 22-09-2014, 18:20
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Looking for slip rings and distributors
I have used these on non-FRC related projects with great suceess: http://www.mercotac.com/html/430.html
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 22-09-2014, 18:38
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
Adafruit has 2 amp ones that you can run PWM cable through, that might be helpful if you can modify your design a little
Unread 22-09-2014, 18:39
FRC #1658
the only unit they have that meets our needs is the model 830. Why do they not list prices???? I imagine they will be 100+ each but if they are too much more than that may be an issue.
Unread 22-09-2014, 18:40
FRC #1658
for the servo no problem, but we still need 2 40 amp channels for the cim and if we are to use a secondary slip ring the cim slip rings needs to be a through hole style.
Unread 22-09-2014, 19:11
Mk.32's Avatar
AKA: Mark
As with most suppliers you have to contact them for a price:
http://www.mercotac.com/html/purchasing.html
Contact info at the bottom, they are local to me so I just drive over and pick stuff up.
These are expensive, have you thought about designing your swerve so it is independent like 1717/others?
Unread 22-09-2014, 19:57
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
I believe Bomb Squid (Team 16) uses slip rings in their swerve. You might try contacting one of them.
461 Westside Boiler Invasion
45 Technokats
Unread 22-09-2014, 20:03
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Even through CIM motors are usually on 40A breakers, they can draw significantly more current for brief periods of time. The breakers do not trip instantly at 40.00001A, they trip after X seconds depending on the ambient temperature and current being drawn. Thus, your slip rings should be rated to handle the stall current of a CIM motor.
Art Dutra IV
世上无难事,只怕有心人.
Unread 22-09-2014, 21:10
Mk.32's Avatar
AKA: Mark
I don't think you need slip rings that can handle stall current of a CIM those would be pretty insane 180amps? .... Just like the breakers I am sure the slip rings aren't going to melt at 40.00001 amps. I would contact the manufacture for a more detailed answer on what they can handle.
Bomb squad if I remember correctly uses one of the Mercotac models...
Unread 22-09-2014, 22:10
Aren Siekmeier's Avatar
on walkabout
The 12 gauge wiring required by FRC rules for circuits on 40A breakers is also only rated for ~40A. The breaker is designed to trip in a way that reflects how the wiring is heating up. I imagine the conductors in a slip ring have similar behavior and can be similarly rated and protected by the breaker. Basically, if the wiring only needs a 40A rating (130A would require 4 gauge wire...), then a slip ring should be fine with that as well. Please correct me if this reasoning doesn't work.
Can someone chime in on any differences between these parts of the circuit and their current ratings?
Unread 22-09-2014, 22:23
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The 2014 robot rules allow slip rings as part of branch circuits "as long as the entire electrical pathway is via appropriately gauged/rated elements." Since a branch circuit is rated for 40 amps and 12/10 AWG wire, the slip ring should be rated accordingly.
Unread 23-09-2014, 01:28
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Link to source? I have been looking for legality stuff on slip rings for a while, but I couldn't find anything on the Q&A or in the official rules, other than that custom circuits are prohibited.
Also, bomb squad uses the Mercotac Model 230 slip ring according to a PM I got a while back. They're ~$100 each online it looks like.
Unread 23-09-2014, 02:22
FRC #1658
independent? not sure what you mean here. can you elaborate?
Unread 23-09-2014, 02:24
FRC #1658
we can't even find slip rings rated for 40A much less the hundreds of amps stall current. those things would be the size of a truck. and i imagine slip rings can also handle higher peaks as well anyway, i'm just trying to get as close numbers based on continuous ratings as I can.
Unread 23-09-2014, 02:27
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Like, able to rotate freely without the cim. Essentially, outsource all wires to areas outside the rotating module.
