Go to Post Great things don't just happen to HoF teams; HoF teams make great things happen. - Siri [more]
Unread 23-09-2014, 02:27
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
Re: Looking for slip rings and distributors
Originally Posted by asid61 View Post
Link to source? I have been looking for legality stuff on slip rings for a while, but I couldn't find anything on the Q&A or in the official rules, other than that custom circuits are prohibited.
Also, bomb squad uses the Mercotac Model 230 slip ring according to a PM I got a while back. They're ~$100 each online it looks like.
aren't those illegal then?. the 230 is only 2 channels at 30 amps per channel and doesn't meet the proper rated requirements of 40 amps?
Unread 23-09-2014, 02:30
FRC #1658
Like, able to rotate freely without the cim. Essentially, outsource all wires to areas outside the rotating module.
well our design not only has a cim rotating with it but also a servo(we are doing a 2 speed shifting swerve, or at least attempting to) so we need some kind of slip ring with 5 channels 2 of which needs to be 40A for the cim. i mean we could just stick wires through the center as people have pointed out but we don't want to have to deal with all the issues related to untangling the wires.
Unread 23-09-2014, 02:57
Aren Siekmeier's Avatar
on walkabout
You can also find through-bore slip rings that would allow you to combine multiple different slip rings with a wide variety of specs. For example these guys.
Some suppliers can also build custom slip rings for you, but you'd have to be careful about the legality of these during the season.
Unread 23-09-2014, 03:11
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
If you look at Pwnage's CIM in wheel swerve ( I think), they have a piece of code that, depending on how far the swerve module has rotated (with three complete rotations in one direction being the max IIRC) automatically turns the wheel the opposite direction to compensate for rotation of the wires. It's a fairly simple fix, and they said it had a minimal impact on reaction speed of the robot.
This would remove the need for slip-rings, which would bring the overall cost of the modules down quite a lot while simplifying construction.
Also, if you don't mind me asking, exactly how are you planning on packaging this swerve module?
(2015-?): 973
(2012-2015): 955
Unread 23-09-2014, 03:25
FRC #1658
thanks. i've found a few potential suppliers but none of them have prices and who knows what kind of lead time is required. sourcing these $@#$@#$@#$@# things is no easy task =\
Unread 23-09-2014, 03:28
FRC #1658
We've done a system like that before and we know it is doable we would just rather avoid it hence why we are trying this approach. it certainly is going to cost more but we want to try this during the off seasons to see if we can perfect it by competition time or go with another system(like the one you mentioned)
not sure what you mean in regards to packaging it, elaborate? As in the over all structure of it or???
Unread 23-09-2014, 08:18
Everyone,
The Mercotac slip rings are not slip rings in the true sense of the word. They are mercury filled contacts and are not legal on FRC robots. If you read the application notes on these contacts, you will see warnings about mercury leakage when mechanically stressed or when max current is exceeded. I contacted the manufacturer and was told that those events are rare but do occur. Mercury spills on an FRC field will close down the event.
Unread 23-09-2014, 10:44
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
2014 R48. Obligatory rules may change next year disclaimer.
Unread 23-09-2014, 10:58
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Everyone,
Ummmm...
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 23-09-2014, 11:13
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Everyone,
Which rule is this illegal based on? Looks like <R8>?
What is the definition of hazardous?
Is there a list of hazardous materials? Mercury isn't mentioned in the blue box next to this rule.
If there is no list, does that mean it is up to the individual inspector to judge the hazardous nature of the material?
As such... isn't the legality of this sort of component determined by the lead-inspector at an event?
Unread 23-09-2014, 11:24
John,
Not sure what to answer here...
Does mercury need to be on a hazardous materials list?
Everyone,
Per Q/A, they were legal in 2006, 2009, and 2011, and illegal in 2010. The reason for them being illegal in 2010 was not because of mercury, but because any type of slip ring was not legal in 2010. There have been no relevant Q/As since 2011.
Unread 23-09-2014, 11:50
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Everyone,
I'm now slightly confused. Were these slip rings legal or illegal in 2014?
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 23-09-2014, 14:23
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
Search "2451 PWNAGE Off-season 2012" for a custom slip ring. This design is not currently legal due to the COTS rule unless the brush assembly is considered COTS since it is the slip ring itself. We have asked First to consider allowing custom "mechanical" slip rings. Let the kids explore the possibilities. Our prototype uses the brush assembly out of a CIM motor and we double up the brushes for each motor wire so this will be more than adequate for powering a CIM. Bag motor brush assemblies could be added to allow for sensors, etc. or possibly used instead of CIM units to bring the size down. We have done testing using these slip rings in the off season with great results. We have been playing around with the idea of rapid prototyping the housings and sharing the designs with the First community if they would be allowed for future seasons. We have also shared our design with Andy Baker and spoken with individuals at Vex.
Unread 23-09-2014, 14:28
Joe,
As far as I know, mercury contacts have never been legal on FRC robots even when slip rings were allowed due the the hazards.
