Go to Post I decided I would keep coming and it just kept getting more and more fun. By the time build season started going I couldn't have quit if I wanted to ^_^ - Mr. Pockets [more]
Unread 24-09-2014, 02:10
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
non-FRC motors and speed controllers
Hi,
I'm building a robot with a club in college and we are looking for 12v motors and speed controllers for the robot's drive system. Currently we are planning to use CIMs and Talons, but I thought that I might get some good insight on where to buy good motors and speed controllers here.
The robot we are building is roughly the size of an FRC robot, although geared more for power longevity and torque.
Thanks
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 24-09-2014, 04:24
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
pastelpony will become famous soon enough
Re: non-FRC motors and speed controllers
Robotshop should carry parts for something a tad stronger than your typical FRC bot.
Team 3525 Head Programmer (2014- ) - Java (Formerly LabVIEW)
Unread 24-09-2014, 10:02
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
May be you might consider using brushless motors and ESC's
Given the high speeds of brushless motors you may gear them way down for lots of power.
Unread 24-09-2014, 14:56
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
I would also consider brushless motors and ESCs. They are really powerful for the price (although there may not be as many gearbox options).
I used these 40A brushed DC motor controller for an industrial project, and they worked like champs: http://www.roboteq.com/index.php/rob...or-controllers
Unread 24-09-2014, 15:01
AdamHeard's Avatar
Lead Mentor
I'm very partial to the Ampflow line of motors, especially now that they have an economy line.
Very, very high power for a brushed motor.
Decently high thermal mass, so they're pretty robust.
Unread 24-09-2014, 17:25
qnetjoe qnetjoe is offline
AKA: Joe Daily
qnetjoe is on a distinguished road
Send a message via AIM to qnetjoe Send a message via MSN to qnetjoe Send a message via Yahoo to qnetjoe
For motors, I usually use motors from pitman express.
For a good smart motor controller I usually use a elmo motion controllers
If your robot is stationary, give some serious thought to using VFDs, there are a lot of really good smart VFDs for the money.
Hope this helps
Unread 25-09-2014, 02:37
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
As said above, brushless motors are good. They're efficient and long-lasting, but tend to have high RPMs at low torque. You will need to gear them down a lot via planetary gearboxes or similar options, if you are using them for arms without leadscrews.
For 12v, any 3s motor and ESC should work.
