Go to Post Everyone needs to please stop now before Karthik starts singing. - dlavery [more]
Unread 23-09-2014, 13:12
panther83 panther83 is offline
panther83 is an unknown quantity at this point
Exclamation Arduino with Robot-Open programming help
I have a arduino with robot open connected to a relayboard (we only are using one of the 4). It is all wired correctly but we need code so when the "A" button is pressed on our logitech controller, it will activate the relay and send power to our solenoid for a second to activate our t-shirt launcher. The code for this will be put into our existing code for a 4motor tank drive coded modified from the example code from robot open/arduino. I personally have no idea what im doing in programming. The relay is hooked up to port 9
Unread 23-09-2014, 22:29
shadowfios shadowfios is offline
FRC #2046
shadowfios is an unknown quantity at this point
Re: Arduino with Robot-Open programming help
I assume you mean port 8 on the relay shield, as there is no port 9.
you would have to add:
ROSolenoid solenoid(9);
before your enabled() function. The 9 is because Robot-Open 0-indexs ports.
you would also need to add:
if (usb1.btnA())
solenoid.on();
else
solenoid.off();
inside the enabled() function.
This would cause the solenoid to mimic the button presses.
However I cannot test this code as I do not have the hardware myself.
also is it necessary for the burst to be 1 second?
Unread 23-09-2014, 22:41
When we try to do if statements it gives us an error that it does not have a type.
Unread 23-09-2014, 22:48
FRC #2046
have you defined usb1 as such:
ROJoystick usb1(1);
Unread 24-09-2014, 11:31
We can't give good advice based on a paraphrase of your code and a paraphrase of the error message. Show us exactly what you're trying to compile, and exactly what the error says. Someone here will probably recognize exactly what needs to be corrected.
Unread 24-09-2014, 13:05
this is our current code, we are trying to hook it up to one of the digital ports on the side car itself instead on directly to the arduino robot shield
#include <SPI.h>
#include <Ethernet.h>
#include <EEPROM.h>
#include <RobotOpen.h>
/* I/O Setup */
ROJoystick usb1(1); // Joystick #1
ROPWM leftmotorone(1);
ROPWM rightmotorone(0);
ROPWM leftmotortwo(2);
ROPWM rightmotortwo(3);
void setup()
/* Initiate comms */
RobotOpen.begin(&enabled, &disabled, &timedtasks);
pinMode(SIDECAR_DIGITAL7, OUTPUT);
/* This is your primary robot loop - all of your code
* should live here that allows the robot to operate
void enabled() {
// Constantly update PWM values with joystick values
// Analog sticks feed back values from 0-255
// 255 - usb1.leftY() to invert a drive
leftmotorone.write(255 - usb1.leftY());
rightmotorone.write(usb1.rightY());
leftmotortwo.write(255 - usb1.leftY());
rightmotortwo.write(usb1.rightY());
if (usb1.btnA(1))
digitalWrite(SIDECAR_DIGITAL7, HIGH);
else
digitalWrite(SIDECAR_DIGITAL7, LOW);
/* This is called while the robot is disabled
* PWMs and Solenoids are automatically disabled
void disabled() {
// safety code
/* This loop ALWAYS runs - only place code here that can run during a disabled state
* This is also a good spot to put driver station publish code
void timedtasks() {
RODashboard.publish("Uptime Seconds", ROStatus.uptimeSeconds());
// !!! DO NOT MODIFY !!!
void loop() {
RobotOpen.syncDS();
Unread 24-09-2014, 13:06
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
The code below, copied from the "digital" example provided with the library should work fine.
#include <SPI.h>
#include <SD.h>
#include <Servo.h>
#include <EEPROM.h>
/* I/O Setup */
RODigitalIO dig1Out(9, OUTPUT);  // DIO channel 9, output mode
void setup()
void enabled() {
  if (usb1.btnA())
    dig1Out.on();
  else
    dig1Out.off();
 * All outputs are automatically disabled (PWM, Solenoid, Digital Outs)
void disabled() {
  // safety code
void timedtasks() {
void loop() {
  RobotOpen.syncDS();
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 24-09-2014, 14:13
this is our current code...
 if (usb1.btnA(1))
What are the correct arguments for the btnA method? Examples show it with empty parentheses usb1.btnA() but you have tried to pass it a number.
You didn't show us the error message, but I'm guessing it says something clear about the mismatch between the expected and supplied parameter types.
Unread 25-09-2014, 10:41
AKA: Anthony Lapp
This issue was solved for the OP offline.
They didn't have their Arduino libraries setup properly...on top of the improper code.
Anthony Lapp
RobotOpen
