Go to Post I'm very certain that specifics are quite interesting but all that keeps going through my mind is, "OOOOOH SHINY!" - Andrew Schreiber [more]
Unread 26-09-2014, 14:20
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
Re: pic: Team 2451 Pwnage Custom Bag Motor Slip Ring
Originally Posted by BBray_T1296 View Post
Also note that (barring some ridiculous design) these will not be spinning nearly as fast as a motor has to. You may be dealing with <5 rotations per second pretty much always. Not the ~100rps of a motor
One of our concerns at first was the fact that there could be full current load with no rotation. In a motor the rotation cleans the brushes and uniformly wears the commutator. In a slip ring for a swerve unit the rotation could be described as sporadic. We were concerned with arcing, pitting of the commutator ring, fusing of the brush to the ring, etc. This is why we used clear polycarb housings on the original prototype. But after running the slip ring for extended test cycles and after disassembly and inspection we found there was no reason for our concerns.
