Go to Post You want to make sure you got a Mike Walker and Billfred at your event so the field runs very smoothly throughout the day. - Arefin Bari [more]
View Poll Results: Do you think 8 MINI-CIMS allowed would be a good idea?
Yes, I'ld love to see what people come up with using 8 MINI-CIMS. 46 41.07%
No, I like the motor rules the way they are! 66 58.93%
Voters: 112. You may not vote on this poll
Unread 26-09-2014, 19:32
AdamHeard's Avatar
Lead Mentor
Re: 8 MINI-CIM SWERVE
Originally Posted by Electronica1 View Post
But that would not allow you to have similar power to a 6 cim tank drive, which is the point of the 8 mini-cim argument right? (I might be missing something) You could have more than 4 modules in order to match the 6 cim power I guess.
You could do a swerve using those fancy mercury free mechanical slip rings and put the motors where they belong (external to the module), and easily do 2 per wheel.
Unread 26-09-2014, 19:38
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
How would you fit two motors inside a wheel?
6 inch wheels. Baxter Bomb Squad already uses them and it would give you 1/2 inch of clearance on ether side. How the gearing would work is a totally different story.
But THIS
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
1592 (2017)
Unread 26-09-2014, 20:15
Originally Posted by Max Boord View Post
But this nuttin'. Try one of THESE! (Just swap the FPs for more CIMs.)
It's not about more/less points of contact with the ground, or about how much power you can put into the drivetrain, or how much traction a given wheel has. It's the balance of all of the above. I don't think that adding two more motors will do all that much--just make ya more likely to be traction-limited instead of torque-limited.
Unread 26-09-2014, 20:24
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
Look at what happen with the change from 4 cim drives to 6 cim drives. They are classes of there own.
Unread 26-09-2014, 20:31
Upgraded.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
1592 (2017)
Unread 26-09-2014, 21:06
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
2 extra motor controllers, 2 fewer available 40A ports on the PDB - 8 Mini CIMs vs 6 CIMs is a lose IMO.
Unread 26-09-2014, 21:15
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
For me too, but If another team decides they would rather have all 40A circuits going to the drive, and only use lower power circuits for the rest of the bot, why should the rules keep them from making that trade-off on their own?
Unread 26-09-2014, 22:27
JesseK's Avatar
FRC #1885 (ILITE)
Drive trains are easy to build. Without understanding the fundamentals, drive trains are very hard to perfect as part of a greater robot with other mechanisms. I feel that increasing the amount of power through to the drive trains is a cop-out low & mid-tier teams who don't bother to try to perfect their drive train. I'd much rather the GDC limit total electric power through the drive train if there were any rule changes in that respect. It would force the trade-offs to be actual engineering decisions rather than "BIGGER IS BETTER RAWR!1".
On top of that, I feel that anyone who mentions 6 CIMs as what led to success in an anecdote should have a gigantic caveat stickied across their post. I don't know about the exact wording, but perhaps it could say something like
Dear FRC participant, 6 CIM drive trains (or 8 MiniCIMs) may lead to some nice zippy acceleration if you "like to go fast". Yet here are some side effects you should consult your robot engineers about:
  • Your drivers keep getting penalties for high-speed ramming
  • Your robot "passes out" for about 30 seconds after getting into a pushing match
  • Your batteries from last year's competition no longer hold a charge for the entire match
  • Your other motor-driven subsystems are noticeably slower towards the end of a match
  • The tread constantly strips off of your wheels when merely grazing another robot
  • Your aluminum output shaft shears
  • The chains snap apart at the master link or eat the teeth off of the sprockets after a quick reverse
These were witnessed, BTW.
Full disclosure, 1885 took a beating by powerful drivetrains at champs this past year. Getting double-teamed as a single-speed 11ft/s drive train got very aggravating very quickly. We endured, had some great matches and I know what to do for next year. We even had our very first actual zero-maintenance and very agile drive train this year across 4 competitions. Hopefully I've presented this in such as way that shows more thought has gone into it based upon several years of drive train design experience, rather than a single competition's worth of bias.
Unread 27-09-2014, 01:18
Oblarg Oblarg is offline
AKA: Eli Barnett
4464 used a 6-CIM drive last year, and I'd be the first to add caveats when we talk about the success it brought us (I've detailed the problems we encountered several times on these boards), but it is important to recognize that every single problem you've mentioned is something that can be either mitigated or avoided completely with proper diligence.
Yes, a young, inexperienced team naively going "MORE IS BETTER!" and mindlessly adding motors to their drive can easily do more harm than good, and designing a 6 CIM drive in a way that doesn't run into the mentioned problems is nontrivial (we had to swap our gearing before champs last year, and it wasn't because we hadn't put a lot thought into the gearing we originally had), but I don't think that every 6 CIM success story is necessarily ignoring or downplaying the negatives, or overstating the positives.
"The breakfast of champions!"
Unread 27-09-2014, 01:28
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Originally Posted by Nuttyman54 View Post
Lastly, it is possible to get 6 CIM power with swerve-style drive, but you can't do it with a module swerve. Concentric swerves that distribut power from two (or even one) gearbox to multiple swerve wheels but are steered independently is a way to do it.
There are no limits on the number of swerve modules allowed. How about six?
Unread 27-09-2014, 01:44
Winnovation already did that one. As I recall... they had a remarkable run that year, and then decided afterwards that they just might have made a mistake. (This was coming from a team that made it to Einstein with a 6-wheel swerve, if memory serves.)
The mistake in question, as I recall, was something to the effect of "Ya know, we didn't REALLY need a 6-wheel swerve for this game."
Unread 27-09-2014, 01:49
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
It would be hard and heavy to make us a 4 CIM, 8 Mini-CIM mechanum drivetrain. But, not impossible.
We will just keep adding motors to our drivetrain until we blow a breaker just by accelerating
Unread 27-09-2014, 01:58
This little challenge has been posed before, but I think it's worth posing again.
Use every motor allowed (or as many as needed) in ONE gearbox. This gearbox could then shunt power to any use on the robot--drivetrain, shooter, arm, intake, whatever--via gears and belts. Imagine having 6 CIMs, a bunch of 775s and/or 550s, the full complement of BAGs, and some PG71s all powering drivetrain... or arm... or whatever...
This is, after all, the sort of thing used to power machine shops in the way olden times: one power source, every tool has a belt off of that source and a clutch to disengage itself...
Unread 27-09-2014, 22:57
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
http://gallery.marswars.org/2014-bui...G_3784.JPG.php
Our swerve was originally setup for 1 cim and 1 mini-cim per module. Ultimately we ended up cutting off the extra spot. Mostly because we wanted to use slip rings and not worry about ripping up wires.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 27-09-2014, 23:19
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
8 mini-cim swerves would be pretty cool, but thinking about it, what advantage does more mini-cims allow?
A swerve drive that is compatible with 2 mini-cims is probably compatible with a cim and a mini-cim, because the mounting and speeds are similar.
So I don't think adding more mini-cims would be useful.
