Go to Post You never know when the GDC will slide in a rule about any robot with a laser must do a laser light show on the floor of the field or face a 50-point penalty :p. - EricH [more]
Unread 09-26-2014, 09:50 PM
Zelda (Team702) Zelda (Team702) is offline
FRC #0702
Zelda (Team702) is an unknown quantity at this point
Setting an absolute value in Java
Hey everyone, I have a question that I've had for quite a while that no one seems to know the answer too. I'm a semi-new programmer for my team, I've been coding for them for about a year or so. I recently took charge of the programming subteam and have switched the team over to Java from C++. Now recently I was reprogramming our robot from Arial Assist and realized I have no idea how to set an absolute value in Java! In C++ I used to be able to use the fabs command, but it doesn't seem to work the same in Java.
If anyone knows the answer to my question please let me know. We are using Talons if that is of any use knowing. Thank you for taking the time to help another team out! I'll be FOREVER grateful.
Unread 09-26-2014, 11:02 PM
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Re: Setting an absolute value in Java
Math.abs(<value>)
2015 Newton Semi-Finalist (3130, 2468, 3310, 537)
2015 Lubbock Regional Winner (2468, 3310, 4799)
2014 Galileo Quarter-Finalist (2052, 70, 3310, 3360)
2014 Colorado Regional Winner (1138, 3310, 2543)
2013 Texas Robot Roundup Winner (3310, 624, 2848)
2013 Archimedes Semi-Finalist (126, 3310, 1756)
2013 Dallas Regional Winner (148, 3310, 4610)
2012 Dallas West Regional Winner (935, 3310, 4206)
Unread 09-27-2014, 01:36 AM
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
^Math.abs() is the way to go.
Just as a thought experiment though, you should be able to make your own abs() function in just a few lines of code. Something like:
double abs(double val)
     if(val < 0)
          return -val;
     else
          return val;
