Go to Post The mediocre do the minimum, then exclaim how easy it is. The exceptional never stop to gloat... they're too busy figuring out new ways to make it even better... - Mr. Lim [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 27-09-2014, 11:37
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Wiring Kit
Originally Posted by timytamy View Post
That's interesting, do you have a P/N for the wire/crimps/crimper that you used? The only failure we had this year was a student getting a bit too excited over cutting cable ties :| However this year we had the luxury of set-and-forget electronics, most cables were installed once in their permanent position, so they weren't stressed too much.
We use all the standard Hansen Hobbies stuff:
Crimper
Terminals
Wire
We had used the exact same crimper and terminals for a few years, and most of the failures took the form of bending failure of all wire strands, so we blame the wire. I don't know off the top of my head the wire that 1687 used before this year (I know it was a lower gauge), but my team plans to use this stuff moving forwards, although we may experiment with other gauges of the high-strand stuff.
The vast majority of failures were of sensor leads related to our shooter gearbox, which we removed for maintenance a few times, and between each event as part of our withholding allowance. Wires that didn't need to be touched after installation such as victor PWMs fared much better.
