Go to Post We want you here, and we want you back. Welcome. - Gary Dillard [more]
Unread 22-08-2014, 22:53
AlexMills11's Avatar
AlexMills11 AlexMills11 is offline
AKA: Alex
FRC #0011 (MORT)
AlexMills11 is an unknown quantity at this point
Re: Team 971's CAD Archive Release
How did you guys figure out all the center to center spacing on your belt reductions in your top jaw?
https://scontent-b-lga.xx.fbcdn.net/...c9&oe=545E6457
Unread 23-08-2014, 00:53
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
It's not center-center spacing. From what I can see, there's a Cam (which looks like a bearing attached with a hex nut) used to adjust the tension of the belt.
Unread 23-08-2014, 07:49
James Kuszmaul James Kuszmaul is offline
NEFIRST CSA
FRC #0971 (Spartan Robotics)
James Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud of
It's not actually a cam, it's just a bolt in a slot which we push on until it is tensioned and then tighten down.
FRC971 (Student) 2011-2014
FRC190 (College Mentor-ish) 2014
WPILib Development 2014-present
Unread 24-08-2014, 16:41
Travis Schuh Travis Schuh is offline
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
Alex,
I uploaded a thread in the CD media that shows the sketch we used for our shooter gearbox (it is the same principle, just a cleaner example of it). The picture is accompanied with a description. Please let us know if you have any further questions about this.
http://www.chiefdelphi.com/media/photos/40812?
Also, for note, we are not entirely pleased with our tensioner slot method. We have found that once you tighten down the bolt, even with a fat washer, the material gets swagged into the slot, and the blot doesn't slide freely the next time. This could be improved with more clearance (in hind sight the .252 clearance was un-necessarily close) coupled with possibly a different clamping method. We will see what we decide to do next season.
Unread 29-09-2014, 21:41
YPatrick's Avatar
YPatrick YPatrick is offline
FRC #1671 (Buchanan Bird Brains)
Team Role: CAD
YPatrick will become famous soon enough
So I was looking at your gearbox and I'm a little confused as to how the CIM motor shaft extension is held on. Is is press fit onto the CIM motor or is keyed?
Unread 30-09-2014, 00:03
Press fit. We did all the math to make sure it won't slip.
Unread 30-09-2014, 00:07
AdamHeard's Avatar
Lead Mentor
Starting in 2011 or so, we'd ream .001 under and just hoped it would work!
We tested torque required to slip and found it exceeded what we need by a good margin. I mean we used a 3-4 ft lever arm w/ some weights.
Unread 30-09-2014, 01:54
Awesome, thanks for the data point! I believe we used a 0.0015 press, which just worked for similar reasons. That was some fun math to do. You can treat the hex like a pressure chamber, and figure out the force required to slip it. I remember calculating that we needed 300 lbs of force to press it on.
This year, we left a step at the end of the bore so we could press it on until it hit the end of the CIM shaft. That worked well. You can see it in the model.
Unread 30-09-2014, 14:52
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
You could also leave a small pilot hole on the end to insert a pin gauge to determine the press depth and to relieve the pressure while pressing on the adapter.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
