#16
Re: WildStang 2015 Beta Testing blog
As an EE in college, we lived for the blinking LEDs. If they didn't shine or blink correctly, our circuits were wrong. Even now, as a systems programmer (think Java), when I put something on an embedded system (think Vuzix glasses with a custom circuit) I still 'live and die' by the blinking of LEDs.
It is good to see we are passing on this obsession to the next generation ![]() Last edited by JesseK : 03-10-2014 at 09:30. |
#17
Based on the available power from the VRM, and on the expectation of having the same wireless bridge next year as we used this year, I wouldn't count on being permitted to use the VRM 5 volt output for anything else. |
#19
I agree, and rules trump anything I ever say.
For powering custom circuits (which have mostly been LEDs lately), we have been using a separate regulator, fed by 12V from the PD board. |
#20
I like your Cable Magic post. I was hoping one of the beta teams would print something like that, since the DIO connections no longer have a lock.
I have a suggestion to possibly improve the DIO cabling further by using Latching Polarized (LP) Connector Housings like these 1x3 Female Housings. At first glance, it seems that with a few cutouts for the latch and the notch, Cable Magic could be modified to accept both LP and standard PWM connectors. The question really is if the resulting part would be rigid enough with less plastic, and withstand repeated latching. I have used the LP connectors in prior years for intermediate sensor and solenoid connections. They have done a good job of preventing accidental disconnects and reverse connections (we had a really bad year with electrical tape covered PWM intermediate connections so we decided to upgrade). I really like the prospect of individually latching DIO channels on the RoboRIO, not sure if it is feasible until I get a test unit. Any insights you and the other beta teams could provide would be much appreciated. |
#21
The software subteam has just published a blog post on their initial work with the Java platform on the roboRIO.
Three in a week? Somebody stop us! |
#22
A quick update - we made a mistake and posted an incorrect board design for one of the MXP expansion boards. The 'original' board design was an older version - please see the update on our blog if you were looking at using this board design.
#23
Can you ssh to the RoboRio?
#24
Yes. ssh, sftp, webdav and the web services are the primary tools for viewing and modifying roboRIO settings. There will still be a formatting/imaging tool for the basics.
Greg McKaskle |
#25
Cool, thanks Greg!
#26
What is the value of the filter cap "C1"? Wait, never mind. It looks like that is just a power indicator LED with current limiting resistor. Last edited by billbo911 : 07-10-2014 at 10:18. |
#27
We changed from surface mount to through hole at the last minute for this set of boards (since there was only 1 SMT part left..), and didn't notice we had missed the value on the schematic. |
#28
Can I make a suggestion for the next Rev. of your MXP Expansion board?
As it is designed right now, it doesn't appear to have any method of securing it to the RoboRio other than the MXP connector it's self. How simple, and cost effective, would it be to lengthen the board so that it overlap the two nutserts in the top RoboRio? Then just have holes in the board line up with the nutserts. That way you would have a securing method on the other end of the board from the connector. |
#29
Did you mean this version?
#30
Thanks Mark, beat me to it.
The only downside to this board is the additional cost of empty space. Probably worth it for security. |
