Go to Post I remember eating dinner once. Long before Build season. Now, we only eat aluminum swarf and disappointment. - BeardyMentor [more]
Unread 03-10-2014, 21:38
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
FRC Team CC is an unknown quantity at this point
Arrow [FTC]: Need Help Programming Joystick via Samantha
Hello Chief Delphi,
We are FTC Team 8660, the Charging Champions. We are a rookie team who needs help programming the Logitech controller provided by FIRST. We are using RobotC. We were able to configure the Samantha module to the router and have made many, many attempts programming it but we're unable to to get it to work. After searching on online blogs, tutorials, and videos for a long time, we were unable to find the answers, so we came here seeking advice. We also cannot get the joystick to work, even by wired connections.
  • What are the complete procedures for successfully setting up a tele-op program?
  • If possible, can you provide us a sample program? (e.g. button A to move backwards, button Y to move forwards)
All help is appreciated. Go FTC Teams!!!
Sincerely,
Charging Champions
FTC Team 8660
Unread 04-10-2014, 00:18
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
Re: [FTC]: Need Help Programming Joystick via Samantha
Here is our Teleop code from last year... see if this helps. Shorter version below.
#pragma config(Hubs,  S1, HTMotor,  HTMotor,  HTMotor,  HTServo)
#pragma config(Sensor, S1,     ,               sensorI2CMuxController)
#pragma config(Motor,  mtr_S1_C1_1,     right,         tmotorTetrix, openLoop, reversed)
#pragma config(Motor,  mtr_S1_C1_2,     left,          tmotorTetrix, openLoop)
#pragma config(Motor,  mtr_S1_C2_1,     tower,         tmotorTetrix, openLoop)
#pragma config(Motor,  mtr_S1_C2_2,     none,          tmotorTetrix, openLoop)
#pragma config(Motor,  mtr_S1_C3_1,     claw,          tmotorTetrix, openLoop, reversed)
#pragma config(Motor,  mtr_S1_C3_2,     flag,          tmotorTetrix, openLoop)
#pragma config(Servo,  srvo_S1_C4_1,    Brake,                tServoStandard)
#pragma config(Servo,  srvo_S1_C4_2,    LeftFlap,             tServoStandard)
#pragma config(Servo,  srvo_S1_C4_3,    RightFlap,            tServoStandard)
#pragma config(Servo,  srvo_S1_C4_4,    Block,                tServoStandard)
#pragma config(Servo,  srvo_S1_C4_5,    servo5,               tServoNone)
#pragma config(Servo,  srvo_S1_C4_6,    servo6,               tServoNone)
//*!!Code automatically generated by 'ROBOTC' configuration wizard               !!*//
#include "JoystickDriver.c"  //Include file to "handle" the Bluetooth messages.
void initializeRobot()
	servoTarget[Brake] = 65;
	servoTarget[RightFlap] = 241;
  servoTarget[LeftFlap] = 18;
  servoTarget[Block] = 237;
  return;
task main()
  initializeRobot();
  waitForStart();   // wait for start of tele-op phase
  while (true)
		getJoystickSettings(joystick);
		if(joy1Btn(7))// claw Up
    motor[right] = joystick.joy1_y2/4;
    motor[left] = joystick.joy1_y1/4;
   else
    motor[right] = joystick.joy1_y2;
    motor[left] = joystick.joy1_y1;
    motor[tower] = joystick.joy2_y1;
   //****************** DRIVER 2 (James) ***************************
   if(joy2Btn(6))// claw Up
    motor[claw] = 128;
   else if(joy2Btn(8))// claw Down
    motor[claw] = -128;
   else
     motor[claw] = 0;
   if(joy2Btn(2))//flinger
		servoTarget[Block]= 170;
		else
		servoTarget[Block]= 237;
	 //****************** DRIVER 1 (Jacob) ***************************
   if(joy1Btn(4))// flag up
    motor[flag] = 100;
   else if(joy1Btn(3))// flag down
    motor[flag] = 50;
   else if(joy1Btn(2))// flag down
    motor[flag] = -100;
   else
     motor[flag] = 0;
   if(joy1Btn(5)) //Right FLAP
    servoTarget[LeftFlap] = 80;
   else
     servoTarget[LeftFlap] = 180;
   if(joy1Btn(6))// Left FLAP
    servoTarget[RightFlap] = 146;
   else
     servoTarget[RightFlap] = 47;
   //*********************** BOTH DRIVERS **************************
   if(joy1Btn(1)&joy2Btn(1))// baton mover
    servoTarget[Brake] = 97;
   else
  return;
task main()
  initializeRobot();
  while (true)
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 04-10-2014, 19:48
FTC4211's Avatar
FTC4211 FTC4211 is offline
AKA: John Stegeman
FTC #4211 (The Bombers)
FTC4211 is an unknown quantity at this point
All of our archived code from the last 2 seasons can be found at: http://www.4211thebombers.org/UsefullLinks.html
The "Team 4211's Block Party Code" and "Team 4211's Ring it Up Code" links contain all the autonomous and telop code that we ran at competitions. They have examples of various techniques and strategies for controlling the robot in telop and autonomous, including how to separate the joystick inputs into different threads to allow faster response times.
To more directly answer your question, here is a program with all the basic telop components you need along with various control schemes for driving a robot and for moving a servo. Just uncomment a section you want to try and it will work on a robot.
#pragma config(Hubs,  S1, HTMotor,  HTServo,  none,     none)
#pragma config(Motor,  mtr_S1_C1_1,     Right_Drive_Motor, tmotorTetrix, openLoop, reversed)
#pragma config(Motor,  mtr_S1_C1_2,     Left_Drive_Motor, tmotorTetrix, openLoop)
#pragma config(Servo,  srvo_S1_C2_1,    exampleServo,         tServoStandard)
#pragma config(Servo,  srvo_S1_C2_2,    servo2,               tServoNone)
#pragma config(Servo,  srvo_S1_C2_3,    servo3,               tServoNone)
#pragma config(Servo,  srvo_S1_C2_4,    servo4,               tServoNone)
#pragma config(Servo,  srvo_S1_C2_5,    servo5,               tServoNone)
#pragma config(Servo,  srvo_S1_C2_6,    servo6,               tServoNone)
#include "joystickdriver.c";
	// put the code to initialize servo positions in here
	// don't put code to move motors in here as that can lead to a DQ
task main()
	initializeRobot(); // initialize robot
	waitForStart(); // waits for FCS to start the match
	while (1)
		getJoystickSettings(joystick); // get new message from joystick
		// 3 common drive control schemes for differental drive robots are below
		/* delete this line and line 29 to run this drive mode
		// drive the robot in tank drive style with the joysticks
		motor[Left_Drive_Motor]=joystick.joy1_y1;
		motor[Right_Drive_Motor]=joystick.joy1_y2;
		/* delete this line and line 61 to run this drive mode
		// drive the robot with 4 buttons
		if (joy1Btn(4)) // drive forward when button 4 is pressed
			motor[Left_Drive_Motor]=75;
			motor[Right_Drive_Motor]=75;
		else if (joy1Btn(2)) // drive backwards when button 4 is pressed
			motor[Left_Drive_Motor]=-75;
			motor[Right_Drive_Motor]=-75;
		else if (joy1Btn(1)) // turn left when button 1 is pressed
		else if (joy1Btn(3)) // turn right when button 2 is pressed
		else // stop when no button is pressed
			motor[Left_Drive_Motor]=0;
			motor[Right_Drive_Motor]=0;
		/* delete this line and line 107 to run this drive mode
		// drive the robot with the tophat on the left side of the controller
		switch(joystick.joy1_TopHat)
			case 0: // drive forwards when top hat is pushed forwards
				break;
			case 1: // drive right forwards when top hat is pushed front right
				break;
			case 2: // turn right when top hat is pushed right
				break;
			case 3: // drive back right when top hat is pushed back right
				break;
			case 4: // drive backward when top hat is pushed back
				break;
			case 5: // drive back left when top hat is pushed back left
				break;
			case 6: // turn left when top hat is pushed left
				break;
			case 7: // drive front left when top hat is pushed front left
				break;
			default:  // stop the robot when no top hat direction is pressed
				break;
		// 3 common servo movement controls
		/* delete this line and line 132 to run this servo control mode
		// move a servo with the joystick
		servo[exampleServo]=joystick.joy1_y1;
		/* delete this line and line 146 to run this servo control mode
		// move a servo to a postition when a button is pressed
		if (joy1Btn(5))
			servo[exampleServo]=0; // change the '0' to whatever position you need when the button is pressed
		else
			servo[exampleServo]=255; // change the '0' to whatever position you need when the button is released
		/* delete this line and line 162 to run this servo control mode
		// move a servo to a forward/backward like a motor when a button pair is pressed
		if (joy1Btn(5))
			servo[exampleServo]=ServoValue[exampleServo]+1; // increase the '1' to make the servo change its position faster
		if (joy1Btn(7))
			servo[exampleServo]=ServoValue[exampleServo]-1; // increase the '1' to make the servo change its position faster
Unread 05-10-2014, 20:35
robotsrule robotsrule is offline
robotsrule is an unknown quantity at this point
You should check out the youtube videos posted by the Robogamers. The channel is RobogamersTV
https://www.youtube.com/user/robogamersonline
Watching their videos helped us a lot. They have one specifically on joystick control programming.
https://www.youtube.com/watch?v=3HF31q2mnfA
The Anderson wiring will probably help as well.
https://www.youtube.com/watch?v=M1FsxbLcM0w
Hope this helps.
