Go to Post When our arm "spontaneously combusted in the middle of the field", your team was the first to offer assistance to help fix it. - KTorak [more]
Unread 10-10-2014, 09:13
449_PeterPeng's Avatar
449_PeterPeng 449_PeterPeng is offline
Iron Fist
AKA: Peter Peng
FRC #0449 (Blair Robot Project)
Team Role: CAD
449_PeterPeng is an unknown quantity at this point
pic: Team 449 Hex Drive
Unread 10-10-2014, 09:18
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: pic: Team 449 Hex Drive
Wow, this is way more elegant that what I came up with for our offseason hex frame! I had really awkward plate mounts on the front/rear rails, and something similar on the sides.
Do you think rivnuts would work to mount the super structure frame to the side rails?
Unread 10-10-2014, 09:24
Oblarg Oblarg is offline
AKA: Eli Barnett
Having been there for the design discussions for this, I can assure you that our first few drafts were every bit as awkward/unsatisfying as whatever you had . It took quite a while (and input from four or five people) to get to a version of the design that we liked.
Peter, great job with this. Really. One of the best designs you've CADed, I wish I were half as good at this as you are.
"The breakfast of champions!"
Unread 10-10-2014, 09:42
Andrew Lawrence
Posts: n/a
What is the angle of inclination on your hex (the angle between a hex diagonal and the vertical)? Looks solid. Any reason you need all that structure just to get the shape? And why the different wheels on the ends?
Unread 10-10-2014, 09:51
JesseK's Avatar
FRC #1885 (ILITE)
I can't speak for him, but given what we went through this past season I know we will want the hex to keep its shape through whatever the game throws at it. The extra structure should help with that.
Unread 10-10-2014, 10:05
Andrew Lawrence
Posts: n/a
It won't hurt, but it's definitely not necessary.
Unread 10-10-2014, 11:27
Iron Fist
AKA: Peter Peng
Team Role: CAD
The angle of between front and side frame is 112 deg and between the two side frame is 137 deg. The odd angles are the tradeoffs from making the frame length whole numbers (24" and 15").
The extra verticle beams in the hex frame is not necessary but good to have. One it can diverge the side impact force from the gearbox. Second, it can serve as superstructure / mechanism mount.
As for the wheel, we choose colson in the center for its durability. But our drive subteams needed more traction. So we decided to use Versa Wheel on the side. However, it's always possible to swap on other type of wheels, onmi or performance.
Unread 10-10-2014, 13:07
Chris is me's Avatar
AKA: Pinecone
We mounted our superstructure with rivnuts in a similar way this year and it worked really well. Rivnuts are awesome for this kind of thing; we use them everywhere.
Can you elaborate?
Unread 10-10-2014, 13:38
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Originally Posted by 449_PeterPeng View Post
How long does it take to swap the transmission? It looks to me that the bolts on the lower end of the transmission go through the inner wall of your 1x2 tubing and then a clearance hole on the outer wall to gain access to that bolt...I was wondering if anything will fall out of place in the gear box due to loosening the bottom half of the plates. Maybe I am wrong and the upper stand-off bolts will be enough to keep things in place for that short amount of time.
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Andrew Lawrence
Posts: n/a
While it does add a secondary (yet redundant) mounting interface, strength-wise it doesn't displace much of the force. In our tests as long as you had sufficient backing from the diagonals to the main 2x1 frame, there would be no need for anything else to be done to displace force (especially useful considering it takes out a lot of unneeded weight).
Were you not getting enough traction with colson wheels before? We've had nothing but fantastic traction with them when needed. The Versawheels (while grippy at first) tend to wear a bit quickly, even if just on the edges of the drive.
Originally Posted by Chris is me View Post
Can you elaborate?
Like I said above, the extra framing around the hex is nice, but redundant, and adds more weight than you need to accomplish the job.
Unread 10-10-2014, 14:03
AKA: Pinecone
In addition to strength, the inner rails are being used to mount the frame to the drive tubes.
Unread 10-10-2014, 14:11
AdamHeard's Avatar
Lead Mentor
I think Andrew's point is best summarized as this drivetrain has two complete, independent frames that are likely strong enough on their own. If they were better integrated, a lot of framing could be eliminated.
The support for the angles also doesn't even need to be a separate frame. For a very minimal (and very strong support), see what we did here.
Unread 10-10-2014, 14:31
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
I wonder if anyone has thought about anti-anti-tpinning frames It seems to me that if your opponents front bumper were split in two (as shown on the top side of the diagram below), they might easily "straddle" the side points of your hexagon making it just as hard (maybe harder?) to get out of a T-pin as a straight side would be.
This isn't a critique of your design directly - lots of teams have been experimenting with hexagonal bases recently
Unread 10-10-2014, 17:02
hzheng_449 hzheng_449 is offline
AKA: Harrison Zheng
hzheng_449 will become famous soon enough
We considered integrating the angle supports into the base frame, but we didn't like how much real estate the supports we considered would take on the 2x1.
Although having a raised secondary frame is heavier, we like the fact that it gives us more vertical space to place pneumatics and electronics. (Our robot for last season was a bit of a mess in terms of packing and that experience heavily influenced this drive's design process).
Additionally, we're at least trying to mitigate the weight gain from the hex superstructure by fabricating the base and inner rails on the superstructure with 2"x1"x1/16" and 1"x1"x1/16" (we normally use 1/8").
Also we're using versawheels mostly to experiment with how well they perform compared to colsons. It's an experimental offseason project, and we figured we may as well try out as many new features as possible.
Unread 12-10-2014, 12:33
AKA: Eli Barnett
These are good points, and we considered them while designing this.
Mainly, we decided that while a single frame is simpler, it makes it harder to really make use of the extra area provided by a hex frame (the picture you've linked shows this pretty well, as pretty much everything is contained in the inner rectangular frame. It also complicates wheel access, which is one of the primary selling points of a WCD.
