Go to Post The weight sounds about right, too. If you need more than 65 pounds for your manipulator, then the drivetrain isn't the part you should be redesigning... - s_forbes [more]
Unread 07-10-2014, 12:13
the.miler's Avatar
the.miler the.miler is offline
taking a break
AKA: Miles Chan
FRC #0846 (Funky Monkeys)
the.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of light
Re: paper: Belt Driven VersaChassis WCD - Step by Step guide
Not to say it couldn't be done with chain. 846 ran without issue through Buckeye, Silicon Valley, Champs, Chezy, and CalGames without any provision for changing chain tension. We nailed the C-C right the first time and never looked back.
Just my own experience. I would be comfortable running chain with the versablocks locked in place after the right chain tension was found. Just make sure your gearbox pilots into the frame.
Member 846 The Funky Monkeys 2010-2014
Team 846 Highlights 2014
lynbrookrobotics.com
becauserobots.org
Unread 07-10-2014, 12:48
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
I know that this system uses two 3-CIM transmissions but with only 2 motors each. Do you think that with the back-and-forth, high impact motion that a typical FIRST drive train will go through, the 9mm belts might not be strong enough? Would 15mm belts be a better choice for a drive train, especially for those who want to add on that third motor to each side?
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 07-10-2014, 13:05
Chris is me's Avatar
AKA: Pinecone
Originally Posted by asid61 View Post
From what I've read, you should put in tensioners regardless because of the tolerances required for belt engagement. Adding a cam tensioner is less than 0.1lbs anyway, so there's no reason not to have one.
If you put in tensioners, you could mess it up. If you don't, you can't. A very minor tradeoff, I know, but it's worth noting. It's surprisingly easy to overtension a belt.
You absolutely definitely do not need tensioners for a belt driven WCD, provided you can machine bearing holes in your drive tube with reasonably good accuracy. Our past three years of robots will attest to that.
We have had poor experiences with 9mm wide belts in the drivetrain using pulleys about this small. Last year several teams had belt failures doing this, though manufacturing issues at Vex may have contributed in addition to undersizing.
To me there's basically no benefit to not going 15mm, and the reliability is *much* higher. Even if it does work, why would you want to gamble on the edge of a safety factor with your drivetrain? All of our 15mm setups have been rock solid.
By the way, a good calculator for belt center distance is here. http://www.wcproducts.net/how-to-belts/ We have had good results with zero center distance added. Your mileage may vary based on your tolerances.
Unread 07-10-2014, 16:39
Oblarg Oblarg is offline
AKA: Eli Barnett
449 ran 9mm belts last year without any issue on their WCD.
Looking at the belt specs (which are conservative - you can get more than the rated torque out of them given how short the lifespan is in FRC compared to industrial applications), if I were running an 8WD I'd probably be happier with 15mm between the two lower wheels. For a 6WD, where the vast majority of the robot's weight is on the center wheel to begin with, I don't think it's a likely problem.
As for why bother with 9mm, it allows one to use the WCP gearboxes with pulleys-in-gearbox just as one would do with chain. Personally, I'm not a huge fan of that setup - if a belt does break (admittedly unlikely but it's better not to tempt Murphy if you can avoid it) it's a royal pain to fix - but even in other setups it's nice and much more compact to be able to fit 2 9mm belts on one pulley than have two pulleys.
"The breakfast of champions!"
Unread 07-10-2014, 16:47
AKA: Pinecone
Making your own pulleys from stock is pretty easy, and buying bigger spacers for a gearbox is even easier!
Unread 07-10-2014, 16:53
AKA: Eli Barnett
The former isn't so easy if you're working solely with a drill press and chopsaw.
Unread 07-10-2014, 20:09
lamk lamk is offline
Ken Lam
FRC #4719
lamk is just really nicelamk is just really nicelamk is just really nicelamk is just really nice
There is a reason not to have one, in that they cost money and can be safely skipped provided you have some other way of keeping the block from sliding.
The easiest way to do this is to simply assemble the thing without the cam, pull the versa-block until the belt is properly-tensioned, and then match-drill from one of the holes in the versa-block through the framing member and bolt it in place. You will then never have to worry about belt-tension again, and can save money on the cams. We did this last year at 449, and it worked perfectly. If your pulley is too close to the framing member to fit a nut on the other side of the versa-block, you can even tap one of the holes and just screw it into the versa-block itself.
I would not recommend doing this with chain.
We have play with the belt tension both by manually pulling the block and using the cam. We find the cam allow us more fine adjustment. To us the cam is a little extra "inconvenience" that we can live with.
Unread 08-10-2014, 12:57
Steven Smith Steven Smith is offline
FRC #3005 (RoboChargers)
Steven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond repute
Small request on this guide (which is amazing by the way)
Would you consider updating it with an estimate on pricing for both materials required for just the drive, and what any parts you feel are the minimum requirements to make a quality drivetrain?
I think the combination of this guide and sufficient budget might allow some teams that would traditionally use the KoP drivetrain to venture out to a slightly more difficult drivetrain. It would be helpful for them to be able to compare the cost of the VEX drivetrain versus the $450 voucher.
Either way, I'll probably make sure a few teams in our area (rookie and otherwise) are aware of this guide. It was excellently written.
2013 - 2017 - Mentor - Robochargers 3005
2014 - 2017 - Mentor - FLL 5817 / 7913
2013 - Day I Die - Robot Fanatic
Unread 10-10-2014, 18:47
Ken Lam
FRC #4719
In terms of cost, there was a thread last year comparing the two drive train:
http://www.chiefdelphi.com/forums/sh...ght=wcd+vexpro
From our experience this is not a harder drive train to build than the KOP drive train. We are very familiar with KOP drive train because we used it in our competition and practice robot for aerial assist. We feel that the Versachassis is very easy to build and configure.
There is not a whole lot of difference in cost between the two drive train for just the chassis. However the KOP drivetrain uses the single speed toughbox mini which one can adapt to the Versachassis, but it requires a custom build plate.
http://www.chiefdelphi.com/forums/sh...=129576&page=2
The ideal gearbox for the Versachassis for team with low manufacturing capability is the 3 sim ball shifter which is more expensive than the toughbox mini. Obviously for the added cost you now have a 2 speed drivetrain.
I will post a spreadsheet with all the parts number and cost when I have a chance.
Unread 10-10-2014, 19:54
FRC #1836 (MilkenKnights)
Shafts would have to be remade(non-trivial) or some how extended.
Unread 27-11-2014, 11:30
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Are larger spacers on the wheels required if going 15mm?
Unread 27-11-2014, 14:15
AKA: Pinecone
Yeah. If you're using 15mm wide pulleys, you'll need roughly 1/4" more in spacers (6mm to be exact) for the wheel with an offset pulley. You may also need larger standoffs for the Vex 3-CIM Ballshifter. The other wheel should be fine.
You do need a lathe to make custom 30+mm wide pulleys if you don't want two 15mm ones, and you may need to modify the outer wheel shafts a bit (may not be enough room for the standard locking collar retension, haven't checked).
Unread 27-11-2014, 15:56
AKA: Ahad Bawany
no team (None)
Would I be correct in assuming the same things apply to the WCP dog shifter? I do know that both pulleys should fit in with no problem, but I'm not sure if the spacer size would change.
