Go to Post No one wants to have the piece that they spent hours swiss-cheesing break in half... - BillCloyes [more]
Unread 11-10-2014, 14:43
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Question Training for offseason tommorow, blew the Main circuit breaker. cause for worry?
Hello,
at the end of a mild practice day, the main breaker got increasingly warm until it stopped working completely (zero continuity).
We switched it out and are OK supposedly, but I am slightly concerned for the offseason tomorrow.
Some background:
  • Picture of robot
  • 4 cim + 2 mini CIM drivetrain
  • 2 CIM + 2 mini CIM kicker
  • Bot is about 10 pounds over the max weight (flexible offseason rules)
Is this an expected fault? we haven't had problems before and ran a regional and went to champs...
Your input, stories and experience is welcome!
Thanks,
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 11-10-2014, 14:53
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Re: Training for offseason tommorow, blew the Main circuit breaker. cause for worry?
If the main breaker gets too hot, it will blow. Using all those motors on a 130 pound *without batteries* robot most likely just over stressed it. Was the practice longer than a normal match? The length might have made the breaker get too hot, blowing it.
Some teams that use 6 motor drive trains take a can of compressed air turn it upside down and blow over the breaker to cool it down between matches. This seems to help with preventing blows.
Unread 11-10-2014, 15:54
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
When you say "blow" do you mean "trip" (i.e. just pop it back), or "fried" (i.e. something inside is irreversibly damaged)?
And yes, the practice session was longer than normal.... with a lot of anti-t-bone maneuvers... (so high amps)
-Paraphrasing JFK
Unread 11-10-2014, 15:58
AKA: Ahad Bawany
no team (None)
Depending on how hot it gets, either can happen. If it fried I recommend checking the size of your battery cables. Are they up to spec? Normally the breaker would trip before frying. I recommend spraying it with the air just to be safe. ALSO, if you accelerate and then decelerate very quickly, it can be a big stress on the breaker. If you need code to slightly slow down your deceleration, you can pm me for some pseudo-code.
Unread 11-10-2014, 17:46
Leav,
The breakers are temperature sensitive devices. If the wire was loose on the either or both of the terminals or the wire part of the terminal, the temperature would rise causing the entire breaker to be warm to the touch. It is possible that is all it was. When the breaker is warm it is likely to trip at a lower current.
Unread 17-10-2014, 15:46
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
For posterity I'd like to comment that it was a misdiagnosis. We ended up finding a loose connection underneath some electrical tape... False alarm!
Thanks for the help, and sorry for the bad info...
-Paraphrasing JFK
