Go to Post Corrected, math isn't my strong point (I went to art school for a reason) - KelliV [more]
  #46   Spotlight this post!
Unread 10-10-2014, 13:58
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: 2015 MRI
Originally Posted by silverD View Post
Progress, nice Try swapping the PWMs for the victors before removing them. Since you have a new DSC, we need to track it down to the PWM cable, victor, wiring, or motor. Keep swapping out pieces of the puzzle. Don't toss out the victors that you swap out quite yet. Most of the time when you are swapping motor controllers you are under a time crunch (prepping for or at a competition). Hang on to and test the controllers when you have adequate time to fully test and possibly fix them (for off-season use only)
It's surprising how many speed controllers over the years I have found to be operational that were initially deemed "bad".
How is everyone coming along in getting their bots up and running?
Yes, we did try swapping around pwm cables and ports and determined that the PWM was most likely bad. It was reading 0 volts on the output side as well, and blinking instead of solid.
I think we are getting some borrowed Victors today, but I won't be able to be present tonight.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
  #47   Spotlight this post!
Unread 10-10-2014, 14:40
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
Re: 2015 MRI
Do you have a spare servo that you could connect to the suspect PWM? (after adding the required sidecar 6V jumper of course)
This could help you determine if the PWM is sending out the correct data and identify the victor as an issue.
If you swapped PWMs with another victor on your board already, then this should have determined this already.
Just my $0.02.
Enjoy!
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
  #48   Spotlight this post!
Unread 10-10-2014, 15:28
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Re: 2015 MRI
Originally Posted by pntbll1313 View Post
2052 has never actually built a practice robot before. This is a completely new robot that we built as a summer project. Since we generally do mecanum we decided to do a 6 CIM shifting WCD robot for the summer project to get some experience with that. We did use our spare pickup arm though so our method of ball pickup is the same as our competition bot. We are entering it as a separate robot so yes, it will be in matches.
What!?! Knightkrawler built a robot that doesn't use mecanum drive! I won't believe it until I see it.
  #49   Spotlight this post!
Unread 11-10-2014, 18:19
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Re: 2015 MRI
MRI was awesome this year! Thanks to 1816 and 2052 for being great alliance partners! Also thanks to 2472 for being an awesome fourth robot! As usual thanks to 2175! It seems like we're either with or against each other in elims in every competition we both attend!
  #50   Spotlight this post!
Unread 11-10-2014, 19:41
Re: 2015 MRI
Qualification and Elimination Results:
Final Qualification Standings
Rank    Team    QS
1	1816	14
2	9001	12
3	3130	12
4	4549	12
5	4778	12
6	4624	12
7	4607	10
8	2175	10
9	3883	10
10	5271	10
11	2530	10
12	3630	10
13	2052	8
14	8	8
15	4536	8
16	4859	8
17	3081	8
18	2220	8
19	4511	8
20	2491	8
21	4993	8
22	2498	6
23	2502	6
24	2472	6
25	4648	6
26	2823	6
27	2574	6
28	2606	6
29	2531	4
30	2181	4
31	2177	4
32	3699	4
33	2846	0
4663 and 3184 were no shows I believe.
9001 was 2175's second entry
8 was 2052's second entry
Elimination alliances and results:
alliance 1: 1816 2052 4607 2472 W
alliance 2: 9001 3130 2502 2491 F
alliance 3: 4549 3883 2530 8 SF
alliance 4: 4778 2175 4624 4536 SF
1 beats 4 in 2 matches
2 beats 3 in 2 matches
1 beats 2 in 3 matches
  #51   Spotlight this post!
Unread 11-10-2014, 19:49
wajirock's Avatar
wajirock wajirock is offline
Safety General
AKA: Mohammed W.
wajirock has a spectacular aura aboutwajirock has a spectacular aura about
Re: 2015 MRI
Thanks! You guys were awesome as well! The finals were incredibly intense! We couldn't have won without you!
  #52   Spotlight this post!
Unread 11-10-2014, 20:33
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumnus
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
Smile Re: 2015 MRI
MRI was indeed intense and fun to watch during eliminations! Thanks to 1816 for choosing us! Thanks to 4607 and 2472 for being excellent alliance partners! MRI was fun and I can't wait till next year! Thanks to all those competed! Congrats to the scholarship winners from 2175! I hope new members on everyone's team got a taste of what competition atmosphere feels like.
  #53   Spotlight this post!
Unread 11-10-2014, 20:39
Puneet4778's Avatar
Puneet4778 Puneet4778 is offline
Team Captain
FRC #4778 (The Stormbots)
Puneet4778 is an unknown quantity at this point
Re: 2015 MRI
Our first time attending MRI was incredible! Thanks for being awesome alliance partners 2175 and 4624, we played some very close matches. Congrats to the champs! This season is going to be competitive with so many awesome teams.
Team 4778: The Stormbots
2015
Minnesota State Championship - 3rd Place
North Star Regional - Quarterfinalists
2014
Minnesota State Championship - Winner (Thanks 2175 and 2052)
Archimedes Division - Participant
North Star Regional - Winner (Thanks 2177 and 3042)
  #54   Spotlight this post!
Unread 12-10-2014, 00:04
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Re: 2015 MRI
Thank You Firebears for such a great event. You were great hosts at a great venue!
I love how Aerial Assist shapes up over the course of the qualification rounds and then really comes to life during eliminations! You can feel the excitement build as the competitors play the quals and really feel out the competition and then come into the elims like prize fighters as the alliances battle every second of the matches.
Thank you 1816 for choosing us, it was the first time we were able to play alongside you in an elim situation and my kids were excited to play with you, 2052, and 2472.
3883 played the elims like a beast. I would hate to be on the receiving end of their charges - awesome drive train!
I loved the fact that the 5 remaining teams from the MSHSL State Tourney all made it into the elims - you could feel the energy in the air during each of the rounds.
This was 4607's first off-season event and we were bit by the bug. Hopefully we are able to make it to Minne-Mini (I registered our team as we were driving back to Becker).
"An error does not become a mistake until you refuse to correct it" ~JFK
  #55   Spotlight this post!
Unread 12-10-2014, 00:14
FRC #4607 (C.I.S.)
Re: 2015 MRI
HELP! I just realized that we left our gamepiece at MRI ! It is pretty unmistakable - it is blue and has our CIS 4607 logo plastered on it. If you grabbed it, please PM me and I will figure out how to get it back.
Thanks!
-Coach Jurek
  #56   Spotlight this post!
Unread 12-10-2014, 10:45
Shrub's Avatar
Shrub Shrub is offline
no team (N/A)
Shrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant future
Re: 2015 MRI
Good luck!!! I'm sure someone already has it.
All in all, MRI was crazy in a good way, especially that final match. Awesome. I'd like to congratulate the two scolarship winners on 2175 and all teams for attending and participating! Also, sorry our lead scout walked off the field. She was too nervous to focus on the fact that you stay on the field.
I wanted to ask, how many teams switched out drive teams for matches, and how did that go? I know when I was Human Player it was slightly chaotic and I have a newfound respect for human players now. (I also noticed about 3/4 through matches a team was looking for their drive team... Hopefully they were found in time)
  #57   Spotlight this post!
Unread 12-10-2014, 12:22
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Re: 2015 MRI
Does anybody know if MRI was recorded and if so where the videos can be found?
  #58   Spotlight this post!
Unread 12-10-2014, 12:55
Re: 2015 MRI
4536 planned to have 4 new drivers, but none of them showed up, so we used last year's drivers for all but one of our matches. We did switch up our HP almost every match though.
  #59   Spotlight this post!
Unread 12-10-2014, 13:05
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: 2015 MRI
2220 was running an 3/4 new drive team. Last year's driver was coaching and the three new members were switching places throughout the day.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
  #60   Spotlight this post!
Unread 12-10-2014, 13:43
Puneet4778's Avatar
Team Captain
Re: 2015 MRI
4778 rotated rookie drivers for the majority of qualifications and a rookie human player through quals & elims. Good way for new members to feel involved straight away!
2015
2014
