Go to Post Isn't that sort of like asking "is that an African or European swallow?" - dlavery [more]
Unread 12-10-2014, 12:35
AdamHeard's Avatar
Lead Mentor
Re: pic: Team 449 Hex Drive
Originally Posted by Oblarg View Post
These are good points, and we considered them while designing this.
Mainly, we decided that while a single frame is simpler, it makes it harder to really make use of the extra area provided by a hex frame (the picture you've linked shows this pretty well, as pretty much everything is contained in the inner rectangular frame. It also complicates wheel access, which is one of the primary selling points of a WCD.
You wouldn't have to put the wheels internal like we did to do the simpler bumper support.
Unread 12-10-2014, 12:44
Oblarg Oblarg is offline
AKA: Eli Barnett
No, but you would have to make the inner rectangular frame smaller, shorten the wheelbase slightly, and complicate access.
"The breakfast of champions!"
Unread 12-10-2014, 16:46
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Great post - thanks for sharing. Also thanks to all those sharing CAD archives that show off hex/oct chassis.
I asked Vex if they would add a 22.5 gusset offering to their VersaChassis line. It would allow those of us without a sheet metal sponsor to build something like this with minimal tools.
-matto-
Unread 12-10-2014, 16:49
Andrew Lawrence
Posts: n/a
-matto-
Could you clarify what a 22.5 gusset is?
Unread 12-10-2014, 17:12
AKA: -matto-
FRC #1410 (Kraken)
Apologies - can't post a pic on a Pic thread apparently =P
http://imgur.com/dkk6jLg
I meant a 22.5 degree gusset. Put one on either end and the existing 135 degree gusset in the center, add some 2x1 VersaFrame and you have a quick hex chassis like the OP showed.
-matto-
Unread 12-10-2014, 18:00
AKA: Eli Barnett
-matto-
449 doesn't have a sheet metal sponsor or access to a CNC mill, actually. We do all our machining by hand with a drill press, miter saw, and band saw.
However, we do have access to a laser cutter that can do delrin, which allows us to make precise templates for our gussets that we can then use to match-drill.
Unread 13-10-2014, 16:00
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Originally Posted by nuclearnerd View Post
I wonder if anyone has thought about anti-anti-tpinning frames It seems to me that if your opponents front bumper were split in two (as shown on the top side of the diagram below), they might easily "straddle" the side points of your hexagon making it just as hard (maybe harder?) to get out of a T-pin as a straight side would be.
This isn't a critique of your design directly - lots of teams have been experimenting with hexagonal bases recently
My team this year had a cutout in the front bumper like you drew. It seemed to be somewhat effective to reduce the effects of teams hex drives. (our bumper cutout gap was 11" to make room for our arm when in the down position) However we really only had the chance to use it against 148 whose hex sides weren't as large as some other teams. In order to prove that the cutout really was effective in this aspect we would have liked to try it out on some different angled hex chassis. I don't know if any other teams can attest to this being an effective way to reduce the usefulness of a hex chassis, but please chime in if you have any other ideas on this.
Unread 13-10-2014, 16:26
AKA: Eli Barnett
I think a hex chassis would still see some benefit in situations up against a wall, since they still have a point to pivot around where the frame contacts the wall (where a rectangular chassis would not).
Obviously, I have no way to test this at the moment. It'd be nice to play around with a few actual bots and see how the different situations pan out.
