Go to Post You inspire your way. I'll inspire my way. - Andrew Schreiber [more]
Unread 12-10-2014, 15:56
nickansh1 nickansh1 is offline
FRC #4777
nickansh1 is an unknown quantity at this point
Reasons for non-functional piston?
Hi everyone,
One of the pistons from our competition bot from last year has spontaneously stopped triggering. Some background information:
-the piston itself works fine as we have tested it manually
-our compressor is functioning and our tanks are holding air
-the spike is functioning and displaying a green light when we attempt to trigger the piston
-our solenoid is functioning
-airlines seem to be hooked up properly
All the individual components seem to be working fine. Also, we find it strange that it stopped working out of the blue when the code has been the same since our competitions.
Any reasons as to why this could be happening?
Unread 12-10-2014, 16:03
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Reasons for non-functional piston?
What pressure is your regulator at? Solenoids can have unpredictable behavior below a minimum pressure.
Unread 12-10-2014, 16:48
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Try taking the air lines out of the offending piston and triggering the solenoid without them in. If the air switches sides like you expect it to, you have a plumbing problem or an air pressure problem (or no problem at all). If the solenoid doesn't switch sides when you expect it to, you have a wiring problem, a code problem, or a underpressure problem (like Joe said).
-Plutarch
Unread 12-10-2014, 18:07
Mr. Mike's Avatar
Mr. Mike Mr. Mike is offline
FRC #3138 (Innovators)
Mr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to all
If the wiring and program checks out OK and the solenoid does not switch the piston could be stuck in the manifold.
Unread 12-10-2014, 21:11
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
How are you testing your solenoid? By pushing the manual trigger buttons or electrically? If you only tested with the buttons and not by applying a voltage directly to the solenoid, then the electrical portion of the solenoid may have failed, or the wire between the solenoid and the Spike may have broken, etc.
FRC 766, 2015-, Mentor
Unread 12-10-2014, 21:35
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Some solenoids have a lock on the manual actuation button. If it is locked to the "on" position.....
Unread 13-10-2014, 07:44
If the relief port is blocked, there is no where for the air on the opposite side of the piston to go.
