Go to Post but yea. people have this perception of robots as like, the terminator. you don't have to be a super genius to do this stuff. - christina_omg [more]
Unread 12-10-2014, 16:48
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: Reasons for non-functional piston?
Try taking the air lines out of the offending piston and triggering the solenoid without them in. If the air switches sides like you expect it to, you have a plumbing problem or an air pressure problem (or no problem at all). If the solenoid doesn't switch sides when you expect it to, you have a wiring problem, a code problem, or a underpressure problem (like Joe said).
-Plutarch
Unread 12-10-2014, 18:07
Mr. Mike's Avatar
Mr. Mike Mr. Mike is offline
FRC #3138 (Innovators)
Mr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to all
If the wiring and program checks out OK and the solenoid does not switch the piston could be stuck in the manifold.
