Go to Post People will only work toward common goals when they are part of the goal-setting process. - GaryVoshol [more]
Unread 13-10-2014, 19:51
nlj007 nlj007 is offline
FRC #0900
nlj007 has a spectacular aura aboutnlj007 has a spectacular aura about
paper: Team 900 Battery Cart
Thread created automatically to discuss a document in CD-Media.
Team 900 Battery Cart by nlj007
Unread 13-10-2014, 19:53
FRC #0900
Re: paper: Team 900 Battery Cart
Team 900 is proud to present our battery cart. Shoutout to 1311 Kell robotics for the inspiration!
If you have any questions feel free to ask!
Unread 13-10-2014, 19:57
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Isn't the SB50 rated for 50Amps? not 120?
Do you charge batteries with this closed? If so are there any heat issues?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 13-10-2014, 20:58
ehoyla's Avatar
ehoyla ehoyla is offline
FRC #1311 (Kell Robotics)
ehoyla is a splendid one to beholdehoyla is a splendid one to beholdehoyla is a splendid one to beholdehoyla is a splendid one to beholdehoyla is a splendid one to beholdehoyla is a splendid one to beholdehoyla is a splendid one to behold
Thanks for the shout out Zebracorns
Our battery box is slightly different but fundamentally the same. We have never had an over heating issue though we typically leave it open unless students are sitting on it. Though we have left it closed for several hours without a problem.
2012: Chairmans Award - Regional Winner - Industrial Design Award - Safety Runner Up
2013: Chairmans Award - Gracious Professionalism
2014: Chairmans Award - Creativity Award
2015: Chairmans Award
Unread 13-10-2014, 21:07
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Nope. It is not possible to close the lid and charge the batteries. There are a lot of people that seem to have that question though. The cart is intentionally designed so that it cannot charge with the lid closed. In fact, it won't close with the batteries left plugged in. The center rail is too high.
The SB50s are indeed rated for 50 amps. I think the student corrected the link but not the wording. We'll correct it. Thanks for pointing it out.
Unread 13-10-2014, 21:24
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
That is a question I'd like to throw some math at.
In typical operation at competition the amount of heat generated is negligible. With 14 batteries, most fully charged and floating there is very little current draw. The couple of batteries that are fast charging are responsible for the most heat.
The math I'd like to do is this..... 14 depleted batteries each being charged by a 5A smart charger. The chargers will be throwing off some heat and the rest of the energy being pushed into the battery.
Question: Does charging lead acid batteries experience a temperature rise while charging ?
The only time the system is working very hard is when we are doing an all day show with 3 or 4 robots running continuously for 8 hours. Batteries are moving so fast it isn't worth closing the lid.
But at competition the heat is not even noticeable, and closing the lid gives us a nice place to sit.
We are making one significant upgrade to the system. We are installing a rail down the center and bolting the SB50 connectors in place, and dressing the wires down. That will be a big improvement.
Ed
Ed Barker
Unread 13-10-2014, 21:28
FRC #0900
Thank you for the feedback! We have corrected the Amp rating and added a blurb on the lid not closing while batteries are plugged in.
Unread 13-10-2014, 21:32
FRC #0900
Ed
Thanks for the input Ed! As shown in this guide, we have the SB50s bolted to a rail down the center with the wires dressed down and out. It makes plugging and unplugging the batteries much easier!
Unread 13-10-2014, 21:36
ebarker's Avatar
AKA: Ed Barker
A little light reading here
The heat coming the battery is I R losses due to internal resistance, and the chemical reaction is exothermic.
And there are some switching losses in the chargers. And yes I still don't have a hard number, and I probably will not go that far. But it is an interesting question.
Ed Barker
Unread 13-10-2014, 21:57
marshall's Avatar
Indeed. Thank you Ed. You have an amazing group of students and mentors working with you and we definitely would not have come up with our cart without seeing yours first.
Unread 14-10-2014, 09:41
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
You could always put a thermometer in the box to test that. Adding vent holes maybe with a small ventilation fan solve any heat issues. Ventilation holes would be a good idea in there is any gassing from the batteries. SLA batteries are sealed after all so gassing really shouldn't be much of an issue for normal circumstances.
Unread 14-10-2014, 20:32
ebarker's Avatar
AKA: Ed Barker
The box naturally has 2 holes, and we add a 3rd large hole for cabling. We are going to put a small fan in on of the holes when we get around to it. Just have not needed it for heat.
Ed Barker
