Go to Post A game where you don't have control of your robot for long periods of time is no fun (unless, of course you are talking about autonomous :p) - Cody Carey [more]
Unread 14-10-2014, 09:30
dragon_pilot dragon_pilot is offline
FRC #0997
dragon_pilot is an unknown quantity at this point
pic: Can anybody give me advice on my Butterfly drive that I am working on?
Unread 14-10-2014, 09:34
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: pic: Can anybody give me advice on my Butterfly drive that I am working on?
Though a 4 speed robot would be cool to see, my first suggestion would be to eliminate your transmission and get your speed and torque changes by a difference in the diameter of your wheels. If you have a small traction wheel and a large omni wheel, you'll get pushing power when in traction mode and speed when in omni mode. This will reduce complexity and give you more room to mount your pneumatic pistons for actuating the modules by making the modules smaller.
Unread 14-10-2014, 09:49
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I'm curious whether he intends to do a 4-speed or not. The major tactical advantage of keeping a 1:1 ratio between the omni & traction wheels is to be able to change from one to the other at full speed. There is also another (huge, IMO) build advantage to this setup which should help answer the actuation question, and it is outlined on slide 3 of this paper:
http://www.chiefdelphi.com/media/papers/2968
I think I need more detail on how the drive train will be run before commenting further. For example, do you plan to use 1 serpentine belt or two belts per side?
Unread 14-10-2014, 10:58
Robotics Engineer
I was just musing on the idea of pulling off a mostly-COTS 4-speed with this design.
While I agree that you could change modes on the fly, I don't see a major advantage of this. If you're changing to traction mode, you're either trying to push or not be pushed. In that case, it'd be better to have the switch to low gear already built into the change of modes than to have to switch to low gear after changing modes. To put it simply, what advantage would low-gear omni mode give you? What advantage would high-gear 4-wheel traction give you?
From my experience, a major goal when developing a drivetrain should be to reduce the mental load on the driver. Having 4 possible drivetrain states for the driver to keep track of sounds like too much.
Based on the size of the pulley on the gearbox, I'd say he's going for a 2 belts per side system.
Unread 14-10-2014, 11:34
JesseK's Avatar
FRC #1885 (ILITE)
Low-gear omni provides safe-zone agility while lining up on a precision game piece or goal, like 2011, 2012 or 2013 (2012 in particular).
High-gear traction provides faster straight-line movement since the 4 traction wheels on the corners make it harder for the robot to turn itself. This is tremendously useful in autonomous 'drive straight' routines like 2011.
Changing to high-gear traction at speed can prevent a robot from being knocked off course while still beating a defender to a point straight ahead.
On the surface I agree with your last point, that 4 modes is a bit much. Yet for the team to be successful with any "butterfly" drive, they will need practice. The modes I've described are fairly intuitive, so it wouldn't be an issue for a team with a nominal amount of practice. I've driver coached lots of students over the years only a few of them would not have been able to handle a more intuitive setup of the modes.
From a mechanical maintenance perspective, 4 modes can be a nightmare given that there are 6 subsystems* with 6 actuation points in the current CAD above and 4 subsystems with 4 actuation points in the 624 design. I like that your design has only 4 subsystems with 4 actuation points and is effective yet simple, but I also know how my team does autonomous and driver training, so it wouldn't be right for us. That's a tradeoff the OP has to decide on as well.
*subsystem here is a contained system which is actuated (i.e. not the drive train frame or wheels which are not actuated). Each shifting gearbox is 1 subsystem, but a non-shifting gearbox is not.
Unread 14-10-2014, 16:18
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
aside from some of the points people have had you are gonna want to put some kind of support between the ballshifters because just having those angle bracket supporting the shifter won't be enough on their own to be supported well
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 15-10-2014, 01:20
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Originally Posted by dragon_pilot View Post
What's the justification behind using belts to connect the two sides? One of the major benefits of a Butterfly setup is the increased mobility of the 4 Omni wheels when driven independently.
Another question, with the traction wheels on the outside, its possible that with a scrub-steer setup and 4wd; That the robot won't be able to turn smoothly since the wheelbase is so long. It would essentially jitter (bounce) over the ground as the side wheels move in opposite directions. Not saying it would happen to this robot, since I don't know it's final weight; but my recommendation would be to place the omni's on the outside and the traction on the interior. It's what nearly every other implementation of Butterfly uses. See this butterfly implementation
Good Luck from your Cross-Town Rivals, see you at BB
(2015-?): 973
(2012-2015): 955
Unread 15-10-2014, 01:25
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Originally Posted by Dunngeon View Post
What's the justification behind using belts/chain to connect the two sides? One of the major benefits of a Butterfly setup is the increased mobility of the 4 Omni wheels when driven independently.
From what I understand, a lot of teams with butterfly link the wheels on each side together so that they don't loose power during a pushing match due to a wheel loosing contact with the ground.
Just an fyi, they had the traction wheels on the outside.
Unread 15-10-2014, 01:56
Pumped
AKA: Ryan
Oh, that makes sense; especially when up against the stronger drivebases.
Suppose I should have made that clearer. Most teams I've seen run on the Omni's the majority of the time, and the axle is run through that wheel because it's the primary wheel. The axle placement on the traction wheel, at least to me, implied that the traction wheel was the primary.
(2015-?): 973
(2012-2015): 955
Unread 15-10-2014, 08:57
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
We found that the pneumatic pistons worked really well (and were pretty small) to switch between omni and traction mode (plus gave the effect of low rider )
If you have any questions, feel free to ask me or the team and they can probably field your questions about it.
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Unread 15-10-2014, 09:26
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
http://www.chiefdelphi.com/forums/sh...#post139026 6
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 15-10-2014, 22:11
75vs1885's Avatar
75vs1885 75vs1885 is offline
AKA: Stephen
FRC #1885 (Ilite)
75vs1885 will become famous soon enough
I am having trouble seeing how the Omni wheels get their power. Also, I didnt see a shaft for the omni wheels....
Unread 21-10-2014, 09:07
Lexlukener's Avatar
Lexlukener Lexlukener is offline
Project Manager/Lead Engineer
AKA: Luke Buckner
FRC #4265 (Secret City Wildbots)
Lexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to all
You could flip the orientation of the ball-shifter and puting on a double 25 chain sprocket inside the 1x2 and route chains to either module.
Unread 26-10-2014, 23:39
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
In Butterfly drive Omni wheels go unpowered, the use of them if is for drifting around.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 26-10-2014, 23:44
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Negative sir, they are powered and normally connected by gear or belt.
http://www.teamneutrino.org/seasons/...bot/butterfly/
R.C.
MadTown Robotics Team 1323
