Go to Post My crotchety old person opinion is that it should be illegal to try to win the award. Do things because you like doing them or because it helps others. Don't do things to win awards. - Madison [more]
Unread 14-10-2014, 14:15
dawonn's Avatar
dawonn dawonn is offline
AKA: Dereck
FRC #2586 (Calumet Copperbots)
dawonn is an unknown quantity at this point
Angry Java, OpenCV, & an Axis Camera
I grabbed the latest copy of the JDK, OpenCV, and Eclipse and I want to simply read in the live video stream from an Axis M1013 camera and display it.
I've spent a few hours at it and found plenty of other posts with code they used to connect to the camera but it appears to be no luck for me.
Here's what I have:
import org.opencv.core.Core;
import org.opencv.highgui.VideoCapture;
public class HelloCV {
    public static void main(String[] args) {
        System.out.println("Welcome to OpenCV " + Core.VERSION);
        System.loadLibrary(Core.NATIVE_LIBRARY_NAME);
        VideoCapture capture = new VideoCapture();
        capture.open("http://10.25.86.11/mjpg/video.mjpg");
        if (capture.isOpened())
            System.out.println("Video link open.");
        else
            System.out.println("Video link not open.");
But the connection never opens, here's the output:
Welcome to OpenCV 2.4.10.0
I can use that url in VLC to view the live stream, so I am of the belief that the camera is correctly configured and the network is properly set up. Suggestions greatly appreciated.
