Go to Post It would be a lot easier if students would quit being so magnificent. Really. - JaneYoung [more]
Unread 14-10-2014, 14:15
dawonn's Avatar
dawonn dawonn is offline
AKA: Dereck
FRC #2586 (Calumet Copperbots)
dawonn is an unknown quantity at this point
Angry Java, OpenCV, & an Axis Camera
I grabbed the latest copy of the JDK, OpenCV, and Eclipse and I want to simply read in the live video stream from an Axis M1013 camera and display it.
I've spent a few hours at it and found plenty of other posts with code they used to connect to the camera but it appears to be no luck for me.
Here's what I have:
import org.opencv.core.Core;
import org.opencv.highgui.VideoCapture;
public class HelloCV {
    public static void main(String[] args) {
        System.out.println("Welcome to OpenCV " + Core.VERSION);
        System.loadLibrary(Core.NATIVE_LIBRARY_NAME);
        VideoCapture capture = new VideoCapture();
        capture.open("http://10.25.86.11/mjpg/video.mjpg");
        if (capture.isOpened())
            System.out.println("Video link open.");
        else
            System.out.println("Video link not open.");
But the connection never opens, here's the output:
Welcome to OpenCV 2.4.10.0
I can use that url in VLC to view the live stream, so I am of the belief that the camera is correctly configured and the network is properly set up. Suggestions greatly appreciated.
Unread 14-10-2014, 16:52
Jared's Avatar
Jared Jared is offline
Re: Java, OpenCV, & an Axis Camera
Try waiting a few seconds between calling capture.open(); and checking to see if it's open. This sort of process can take a few seconds to finish up.
Unread 14-10-2014, 16:54
dawonn's Avatar
AKA: Dereck
Unhappy Re: Java, OpenCV, & an Axis Camera
I polled the isOpened() command for a while, and added a delay after the open, same result.
The open() command returns false, is that normal?
I also set up a test in python, with the same results.
Unread 14-10-2014, 17:48
dawonn's Avatar
AKA: Dereck
Red face Re: Java, OpenCV, & an Axis Camera
As an update, I found this chunk of code, and it showed the video feed:
http://www.chiefdelphi.com/forums/sh...96&postcount=3
Although that snippet is in python, that's one step closer to solving the mystery here. I still want to know how to use the opencv VideoCapture class so that I can program in Java, suggestions very much appreciated.
Unread 14-10-2014, 18:09
dawonn's Avatar
AKA: Dereck
Smile Re: Java, OpenCV, & an Axis Camera
The solution for python was on:
https://stackoverflow.com/questions/...11998#24211998
But I still need a java solution.... Any help would be appreciated.
Unread 15-10-2014, 09:31
dawonn's Avatar
AKA: Dereck
Talking Re: Java, OpenCV, & an Axis Camera
I finally have it working in Java and python. I simply copied opencv/sources/3rdparty/ffmgeg/opencv_ffmpeg_64.dll to c:\windows\system32\opencv_ffmpeg2410_64.dll
and ran the java application and it worked as expected~!
