Go to Post I love FIRST... - jess523s [more]
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 16-10-2014, 09:50
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Optimal board for vision processing
Originally Posted by marshall View Post
I agree 100% with this. That's why we have started down the road with the Tegra boards. Despite what FIRST says, FMS Lite != FMS. There are some oddities with FMS that only occur when you are on a field with full FMS and not in a lab.
I am not clear on the TCP/IP stack performance of the RoboRio but on the cRIO if you used the ethernet on the robot to interface your coprocessor (for vision in this case), even if the goal was to send information only to the cRIO locally, you could overwhelm the cRIO. There is a fine write up of the details in the Einstein report. So just be careful the Tegra boards have respectable power if you send your cRIO/RoboRio lots of data you could have this issue.
Not sending real time video payloads over the WiFi will not remove the possibility in which you could send so much data to the cRIO/RoboRio via the ethernet port you still prevent it from getting FMS packets.
If one interfaced to the cRIO/RoboRio over the digital I/O for example. Then the coprocessor could send all the data it wants but the cRIO/RoboRio might not get it all from the coprocessor and will continue to get FMS packets so your robot does not suddenly stop. Effectively giving the coprocessor a lower priority than your FMS packets (and that is likely the situation to really desire).
If the RoboRio stops using the ethernet port for the field radio then this may be less an issue because the FMS packets would not be competing on the ethernet port (they would be on a separate network stream). I know some alpha testing for the RoboRio was around the Asus USB-N53 Dual-band Wireless N600. At least then the issue is purely one of the RoboRio software keeping up with the combined traffic from the ethernet port and the USB networking device (only real testing would show how well that works out and for that you need robots on a competition field, test equipment and things to throw data at the RoboRio (laptops, Jetson boards, etc.)).
