Go to Post Those chief delphi kids...they think they're so pimp... - Eugenia Gabrielov [more]
Unread 15-10-2014, 22:56
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: FRC3880 - Tiki Techs - 2015 Prototype Drive
If you could consolidate your gearboxes into two 3 cim gearboxes, you could save a ton of weight and motors. I don't see the point in adding the power above 6 cims, unless you're planning on hitting 20 fps+ with 0.01s less time(not really math, just an order of magnitude calculation).
Unread 15-10-2014, 23:16
Aren Siekmeier's Avatar
on walkabout
As others have pointed out, there isn't much reason to go with 8 motors over 6, or even 4.
But even if you insist on 8, or at least having the option to mount more motors, you can still save a considerable amount of weight and improve performance by combining 4 on a side into a single transmission, with two output shafts. You can still do so with the WCP DS components.
Duplicating the shifting mechanism on both sides adds quite a bit of weight and cost and means that shifting may not be synchronized. Separating powertrains between front and back means that you could lose half your power if you're wedged or tipped up on your back four wheels. And there's more friction and inertia with all those stages.
Also, mounting the encoder on the input cluster like you've shown will introduce quite a bit more backlash between the encoder and your wheels, and will require knowledge of the precise shift state to schedule gains properly. Combining everything into one gearbox should give you some options to keep the encoder on the gearbox if you need to, while putting it much closer to the wheel, preferably downstream from the shift mechanism.
Unread 16-10-2014, 02:08
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Apparently, hex/octagonal, chain-in-tube, CIM-over-center-wheel WCD is the new fad in DT Design.
Don't miss the forest for the trees here people.
This is coming from a team that rocked an octo-WCD in 2014.
Consider performing a honest and thorough weighted design table to determine if some of the innovations you are proposing actually outweigh the costs.
I would encourage all teams to practice this evaluation method in the pre-season. Just like there is no better time to learn CAD and DT Design, there's no better time to learn how to objectively evaluate designs based off a set list of requirements/criteria (trust me, this is no easy task. It is arguably harder than actually designing the mechanism!)
Beyond big-picture, love the effort being put forward. Winners are made in the off-season!
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 16-10-2014, 02:30
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
I detect a serious lack of power and weight in this drivetrain. Far too little power, you'll get pushed all over the place, and not nearly enough material, your robot will float away in a light breeze. I would also certainly increase your gear count, you can never have enough reductions, efficiency can be dangerous. Additional gears certainly help your weight situation too, 4 individual gearboxes certainly capitalizes on this.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
Unread 16-10-2014, 03:52
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Originally Posted by Andrew Lawrence View Post
I really have a hard time believing that this drive system even without the electronics is 25 lbs.
He says in the previous image that EACH gearbox weighs 15lb. Something is very wrong somewhere with weights in this CAD model as the WCP 3 CIM shifter this looks similar to would weigh 8.5lb with 1 CIM and 1 MiniCIM. I suppose the 15lb could be referring to each SIDE of the drive, ie. 2 of these put together, that gives a much more reasonable number. Still thats 30lb in just gearboxes, so, going under the stretch assumption that 25lb is this drive WITHOUT gearboxes thats a 55lb drive, which sounds much more reasonable.
All of that is a moot point though because OP has stated that the only reasons that there are 2 gearboxes per side is because they don't currently have the ability to make large enough plates to combine them, and that they want to be able to use the gearboxes elsewhere when the project is done.
A side note to that, MOE has had some success making plates that are larger than the travel distance of our mill by splitting the drawing into 2 parts with 1 shared hole. The shared hole is used to align the second drawing to the plate. You will also need 2 flat reference sides. This may not be possible in your situation and it may not be accurate enough for gear spacing but it worked well for chain.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 16-10-2014, 05:10
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Originally Posted by Gregor View Post
I would not feel comfortable putting half the weight of my robot into gearboxes. This is even ignoring the breaker issues of an 8 motor high traction drive.
Ok my bad. I am new to the iProperties thing.
This should have been caught by me, knowing that the CIMs together weigh about 5lbs.
There is no way that transmission weighs 9 lbs!!! More like 3.
The transmission is basically a hybrid of a WCP 2 CIM DS, 2.15lbs. and 3 CIM DS, 3.5lbs. Weight will be between that since it is basically a stretched DS if you will. A 2CIM DS with one extra idler. We went with an idler gear instead of belts. Much easier for us, we had it on hand.
The entire transmission was designed using the existing gears from our 3CIM DS making it easy to test by just replacing the frames. Future orders of different gear ratios from WCP will just work.
Last year we used the WCP 3CIM DS and are extremely happy with it. Never had any issues with breakers tripping on our 6 wheel WCD but space was tight.
We wanted a stretched 2 CIM DS, if you will. That was set up for in-frame chain setup and over the frame motor orientation. (see hex frame).
Being able to orientate the motors in either direction and a quick and easy encoder placement was the goal.
Our competition bots have always had a post tapped into the front or rear axle that the encoder used. Not always pretty..
Something different for us..
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 16-10-2014, 11:12
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Originally Posted by Abhishek R View Post
Oh, I didn't realize there was a drop. I faintly remember team 118 having to use different sized wheels because they could not enough space in the tube to have a big enough drop with the sprockets and chain. Did you have a solution to that problem or did everything seem to fit inside the tube just fine?
I think the difference is that 118 used a 1x2 tube so there no room for wheel drop. The 3880 prototype uses 1.5x3 tube so they have plenty of space.
2015 Newton Semi-Finalist (3130, 2468, 3310, 537)
2015 Lubbock Regional Winner (2468, 3310, 4799)
2014 Galileo Quarter-Finalist (2052, 70, 3310, 3360)
2014 Colorado Regional Winner (1138, 3310, 2543)
2013 Texas Robot Roundup Winner (3310, 624, 2848)
2013 Archimedes Semi-Finalist (126, 3310, 1756)
2013 Dallas Regional Winner (148, 3310, 4610)
2012 Dallas West Regional Winner (935, 3310, 4206)
Unread 16-10-2014, 14:19
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Makes sense, didn't realize it was 1.5x3.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 16-10-2014, 21:02
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Ah, ok, that makes sense. A 9lb transmission would be ridiculous.
However, that being said, I still higly recommend you consolidate your side gearboxes into one gearx each. There is no purpose to having 4 IMO.
Unread 18-10-2014, 21:33
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
Anyone ever hear of battery voltage drop causing cRIO to restart? ;p
I say this partly jokingly, but partly practically. Even with 6 CIM WCD we were dropping out consistently during offseason when we changed our ratio to about 9fps.
We are looking into limiting acceleration/deceleration, current limiting code, etc.
Unread 19-10-2014, 17:59
nathannfm's Avatar
AKA: Nathan
FRC #3940
See if you can check your driver station logs for the voltage graph during your matches, that sounds like you might have some bad batteries.
Unread 26-10-2014, 18:50
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Where might I find CAD models of the colson performa wheels? I am looking for a variety of them but don't know where to look. But what you have pictured is 4x1.5 and 4x2 if I am not mistaken and would be a good starting place for me. Any help is appreciated. I have checked 3dcontentcentral with no luck. Also google hasn't come up with a match yet.
Edit:
After more looking I found what I needed. Thanks.
Unread 26-10-2014, 21:07
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
It can also be a CAN brown out.
Unread 26-10-2014, 23:23
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Over kill, much?
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 27-10-2014, 09:32
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Edit:
Where did you find them?
I wind up making a generic gray-colored cylinder with rounded edges for my models.
