Go to Post The secret to this whole thing is that it's the robot that builds the team. - JohnBoucher [more]
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
  #32   Spotlight this post!
Unread 16-10-2014, 13:25
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Re: Optimal board for vision processing
Originally Posted by techhelpbb View Post
I am not clear on the TCP/IP stack performance of the RoboRio but on the cRIO if you used the Ethernet on the robot to interface your coprocessor (for vision in this case), even if the goal was to send information only to the cRIO locally, you could overwhelm the cRIO. There is a fine write up of the details in the Einstein report. So just be careful the Tegra boards have respectable power if you send your cRIO/RoboRio lots of data you could have this issue.
I feel like this information is misleading to some and might cause people to deter from trying a solution that works for them, because they feel the hardware we have can not support it. What is your definition of "lots of data". This just doesn't happen as you make it seem with the statement "even if the goal was to send information only to the cRIO locally, you could overwhelm the cRIO" or "Tegra boards have respectable power if you send your cRIO/RoboRio lots of data you could have this issue" The problem is not with the cRIO, or with the RoboRio, it is with the operating systems they run on, and the network drivers included with those system. The cRIO runs on vxWorks 6.3. That OS has a single FIFO network buffer for all sockets. It is possible to fill up the network stack, and thus causing any new packets to be dropped, but only if you are constantly sending packets to the controllers NIC, but not reading it off the queue. This happened to our good friends on Einstein that year, because they had a condition where they could enter an infinite loop in their code, causing the code to read data from queue they were sending from the beaglebone white to not be executed.
As long as you are reading from the queue faster then you write, and your code doesn't halt. You should never run into this problem on the cRIO. A properly threaded TCP or UDP communication protocol programmed by the user for controller to off-board processor can't overwhelm the network. We used a bi-directional TCP communication protocol sending data from our off-board processor at a rate of 20 times a second with out any packet loss or communication issues in the 5 events we have played in 2014 so far.
At the end of the day, as long as you can read data off the NIC faster than you can send (which should be easy to achieve) then you should never have this problem above. Its that simple. The Rio is linux based, and operates a bit differently, but it is still possible to run into this issue. The benefit to the Rio being linux is that more users are familiar with linux and can diagnose if the stack is full. The user should be able to see the buffer state by reading
/proc/net/tcp
or
/proc/net/udp
Those files provide a ton of info on the corresponding protocol, including the count of items in-bound and out-bound in the queue. You can read the spec to see what each field of data means. http://search.cpan.org/~salva/Linux-...roc/Net/TCP.pm
The EINSTEIN report from 2012, when this was noted is documented here: http://www3.usfirst.org/sites/defaul...n%20Report.pdf
Not sending real time video payloads over the WiFi will not remove the possibility in which you could send so much data to the cRIO/RoboRio via the ethernet port you still prevent it from getting FMS packets.
Why do you state that sending real-time video can aid in flooding the cRIO queue, even though the packet destination is the driver station, and not the cRIO/RoboRio. What you are describing sounds like the D-links ports act like a hub, instead of a swtich, do you have evidence of this?
What do you consider real-time? Again the problem you are mentioning is a worst-case senario, if you only send packets to the cRIO, but never read them, you will fill up its network buffer, as is expected. It is not unreasonable.
We transmit 320x240 images at 20 frames per second from our off-board processor, to our driverstation. I consider this to be real-time, and we don't have issues and because of the small image size, with mostly black background, we are way under 3mbits per second bandwidth (which is a safety factor of more than 2 on the link limit.) Since we use an off-board processor, The transmission starts with our off-board processor, and ends with a separate thread running on our driverstation. The cRIO is not aware of the transmission, because the d-link acts as a switch and routes based on MAC address, the pictures destined for the driverstation, should not flood the cRIO. A proper working switch as the D-link is advertised to be, only routes packets to individual ports, not all ports. If you have evidence of your claim to the contrary, please provide it.
If one interfaced to the cRIO/RoboRio over the digital I/O for example. Then the coprocessor could send all the data it wants but the cRIO/RoboRio might not get it all from the coprocessor and will continue to get FMS packets so your robot does not suddenly stop. Effectively giving the coprocessor a lower priority than your FMS packets (and that is likely the situation to really desire).
IF you plan to bit banging data over IO, or even multiple IO your throughput will suffer. This may work for small communications, but will be a hindrance for more data, or even scalability. I also believe it is more complicated if the user requires bi-directional communication than using Ethernet. If flooding the network queue was of concern even after designing a proper communication protocol, I would recommend people to reduce the Time To Live on the packet, so that if it does get queued up, it is not sitting in the queue for more than 2 seconds.
If the RoboRio stops using the Ethernet port for the field radio then this may be less an issue because the FMS packets would not be competing on the Ethernet port (they would be on a separate network stream). I know some alpha testing for the RoboRio was around the Asus USB-N53 Dual-band Wireless N600. At least then the issue is purely one of the RoboRio software keeping up with the combined traffic from the Ethernet port and the USB networking device (only real testing would show how well that works out and for that you need robots on a competition field, test equipment and things to throw data at the RoboRio (laptops, Jetson boards, etc.)).
As an Alpha and Beta tester, the ASUS was proved to be too problematic, and will not be approved for use. We will continue to use the D-link for at least the 2015 competition season.
I second what Jared states on camera and network setting. I will be releasing a comparison of RoboRio vs BeagleBone Black vs Jetson (CPU) vs Jetson (w/GPU) sometime in the near future as I have access to all of those boards, and they are all linux/ARM and can run the exact same code.
We used an off-board process mainly for reliability. Which is why I wanted to chime in. We like the segregation of keeping the vision system separate from our main robot. IF the vision fails, we get a null image, or any of a mirage of things happen on the vision side, the way we have the robot coded, it does not affect the robots ability to communicate, and play the game (without vision of course). We ran into issue at an off-season event where the SD card on our beagle-bone white began to fail, and would not load the OS properly on startup, all this meant is we could not detect the hot goal, and a backup auto routine was performed ( just shoot 2 balls in the same goal and one will be hot). It did not bring down the robot at all. If the camera becomes unplugged, or unpowered, it does not create a null reference on the robot, which I have seen many teams have dead robots in Auto, because their camera was unplugged when put on the field, and the code started with a null reference.
I realize our rationale if different than your post which has a tone of more bad than good in my opinion, but I would definitely advocate for an off-board processor. Another reason we go with an off-board processor is because of what happened in 2012 and 2013 where certain events actually disabled streams in order to guarantee up-time on the field. This handicapped any team that depended on vision processing on their driverstation. I still like to believe that the 7Mbit/s stream is not a guarantee from FIRST, so depending on it is a bad idea. If you must rely on vision, doing the processing locally on the RoboRio, or an off-board processor is a way to avoid this (because the data stays on the local LAN) and doesn't need to be transmitted to the DS. Although I am open to any evidence that this is not true for the D-LINK DAP 1522 as is suggested in this thread.
For these reliability reasons, even though the RoboRio probably holds enough juice for our needs, we most likely will still continue to use an off-board processor to keep the major software of our system segregated, if we even have vision on our bot! As others have said, vision should only be a last resort, not the first, their are more reliable ways to get something done, like more driver practice! We didn't use vision at all in 2012, and ranked 1 in both of our in-season competitions.
Our robot is and always will be developed to play the game without relying heavily on vision. We do this with dedicated driver training. Vision is only added to help, or make an action quicker, not replace the function entirely. Our drivers still train for a failure event, and we try to design our software so that if any sensor fails, the driver is alerted immediately, and the robot still operates to complete the match without much handicap.
Regards,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
