Go to Post One button, ten copyrights, you do the math. - StephLee [more]
Unread 16-10-2014, 14:40
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Re: pic: Tiki Tech Transmission
Originally Posted by themccannman View Post
You are making a drivetrain that is 58.8lbs *without* the frame? Are you making the rest of your bot out of carbon fiber?
REPEAT of what was posted in the Prototype Frame...
Ok my bad. I am new to the iProperties thing.
This should have been caught by me, knowing that the CIMs together weigh about 5lbs.
There is no way that transmission weighs 9 lbs!!! More like 3.
The transmission is basically a hybrid of a WCP 2 CIM DS, 2.15lbs. and 3 CIM DS, 3.5lbs. Weight will be between that since it is basically a stretched DS if you will. A 2CIM DS with one extra idler. We went with an idler gear instead of belts. Much easier for us, we had it on hand.
The entire transmission was designed using the existing gears from our 3CIM DS making it easy to test by just replacing the frames. Future orders of different gear ratios from WCP will just work.
Last year we used the WCP 3CIM DS and are extremely happy with it. Never had any issues with breakers tripping on our 6 wheel WCD, but space was tight.
We wanted a stretched 2 CIM DS, if you will. That was set up for in-frame chain setup and over the frame motor orientation. (see hex frame).
Being able to orientate the motors in either direction and a quick and easy encoder placement was the goal.
Our competition bots have always had a post tapped into the front or rear axle that the encoder used. Not always pretty..
Something different for us..
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Division TBD | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
